Author Topic: Vertical sync problem?  (Read 2583 times)
Endprodukt
  • Last login:September 08, 2026, 05:50:12 am
« on: April 08, 2016, 12:49:42 pm »
Hey,
I have a problem with the vertical sync that I didn't have before I did an update to 2.0. The "sweetspot" for the vertical sync seems to be soooo tight I have to redial it each time I start the cabinet.
Is it possible to change something in the modelines/presets (I'm on pstar25) to solve this?
Best,
Olli
Endprodukt
Re: Vertical sync problem?
« Reply #1 on: April 11, 2016, 08:40:34 am »
Anyone? Rolling screen gets sometimes to the point it will barely sync. Starting games like mk will need redial. I didn't have that problem on version 1.
Calamity
  • Moderator
  • Last login:September 06, 2026, 03:54:00 am
  • Quote me with care
« Reply #2 on: April 11, 2016, 10:26:37 am »
You probably have to change the vertical sync polarity in your Polostar preset.
Steps to create a log:
Endprodukt
« Reply #3 on: April 11, 2016, 03:52:45 pm »
Since I don't want to destroy anything or make it even worse, could you point me in the right direction? It would be appreciated.
Calamity
  • Moderator
« Reply #4 on: April 13, 2016, 04:39:30 pm »
Create a custom preset based on the polostar one, then change the polarity values (0 is negative, 1 is positive):
http://forum.arcadecontrols.com/index.php/topic,116023.0.html
