Author Topic: U360 Ultrastik - Restrictor settings on Linux  (Read 5961 times)
pskerrett
  • Last login:April 02, 2016, 04:20:43 pm
« on: April 02, 2016, 03:58:34 pm »
Hi,
I just installed a restrictor plate on my Ultrastik, and am trying to configure the device to allow me to get the full signal level out with the plate on. IE, prior to the plate, I was getting axis signals of about 32,000 using jstest for /dev/input/js0
Now I'm getting 16,000 which makes sense, but analog control based games are not fully functional.
I have ultrastikcmd compiled & functional, but am not sure how to use this to tell the stick that it has a restrictor installed.
pi@retropie:~ $ sudo ultrastikcmd -c 1 -v
Write to flash: No
Use restrictor: No
Border locations::
 0x1e  0x3a  0x56  0x72  0x8e  0xaa  0xc6  0xe2
device identification of HIDInterface 001/007[2]:
  dev_handle:    0x019fa9b8
  device:        0x019f4530
  manufacturer:  Ultimarc UltraStik
  product:       Ultimarc Ultra-Stik Player 1
  serial number: 1
Bind-driver request sent to the kernel
There is a '-o' command that says 'use restrictor' which works initially -
Report bugs to andrewsi@outlook.com.
pi@retropie:~ $ sudo ultrastikcmd -c 1 -o -v
Write to flash: No
Use restrictor: Yes
Border locations::
  dev_handle:    0x0124d9b8
  device:        0x01247530
  serial number: 1
But that value does not get saved:
Write to flash: No
Use restrictor: No
Border locations::
  dev_handle:    0x014ba9b8
  device:        0x014b4530
  serial number: 1
How do I program this into a map file or something to allow it to save?
Thanks.
