Author Topic: Vetrex Overlays in MAME/MESS  (Read 2295 times)
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
« on: March 19, 2016, 10:13:17 pm »
I am having trouble getting the correct vectrex overlays to load when I launch a game in MAME.  I searched the internet and this is the best I can come up with as a command:
mame64 vectrex scramble -view scramble
It loads the game, but then uses the last overlay I used.  Once the game is launched, I can change to the correct overlay by using the video options in MAME.
Any thoughts?
nexusmtz
Re: Vetrex Overlays in MAME/MESS
« Reply #1 on: March 21, 2016, 01:12:10 am »
The command line works until the first time you choose a view from the menu. When you exit, that choice gets written to cfg\vectrex.cfg and the command line doesn't override it.
If you remove the view="xyzgame overlay" part of the target line in the video section of the cfg file, the command line view selection will start working again.
You can remove just that entry, the whole line, or delete the whole cfg file, depending on how much reconfiguration you want to do. For example, if you had turned the crosshair off within Vectrex, then deleted the cfg file, you'd lose that setting too.
