April 08, 2026, 02:56:39 am
I think these are supposed to work OK, but add about a frame of lag.http://www.amazon.com/KingMas-GBS-8220-Arcade-Video-Converter/dp/B0051SLJAGThere really isn't a good product out there for this though. I remember that CraftyMech was working on a CGA to VGA converter with built in scanline generation, but I don't think anything ever came of it.
I tried one of those with a Centipede pcb. The lag was horrible.
Quote from: yotsuya on March 19, 2016, 06:36:40 pmI tried one of those with a Centipede pcb. The lag was horrible.If that's the case, I don't think he really has any good options. Probably have to use a PC and MAME.
Aw, man, if you're going to go through the trouble of using an original board, you should try to use an original monitor as well.
Yeah, the choice of original board and VGA LCD is a bit baffling to me. Better off using MAME.
Quote from: CheffoJeffo on March 21, 2016, 03:45:30 pmYeah, the choice of original board and VGA LCD is a bit baffling to me. Better off using MAME.It's not like he's losing anything using MAME, the emulator for Pacman has been perfect for a long time.
Quote from: dmckean on March 21, 2016, 05:03:54 pmQuote from: CheffoJeffo on March 21, 2016, 03:45:30 pmYeah, the choice of original board and VGA LCD is a bit baffling to me. Better off using MAME.It's not like he's losing anything using MAME, the emulator for Pacman has been perfect for a long time.Right. That's why wanting to use an original board with an LCD is a bit uninspired.
