Author Topic: Wiring a P360 to an IPAC  (Read 3186 times)
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« on: January 14, 2004, 09:53:32 pm »
The tabs on my P360 are:
Up / down / left / right
Ground
+5V
Up / down / left / right, is pretty straight forward, and I'm assuming "ground" on the P360 connects to one of the IPAC ground screws.
But....what terminal does the +5V connect to?
%$#@!&* machine took my quarter!
OSCAR
    • Oscar Controls
Re:Wiring a P360 to an IPAC
« Reply #1 on: January 14, 2004, 10:19:02 pm »
I powered my P360's right from the header on the I-PAC.  There is a pic in this thread:
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=8916;start=msg65651#msg65651
There is a schematic here so you can identify the +5V pin on the I-PAC header: http://www.ultimarc.com/ipac2.html.
dac
  • Last login:May 27, 2005, 10:13:46 am
  • newb
« Reply #2 on: January 14, 2004, 10:22:53 pm »
this can be confusing,
I've seen (and asked) this question before, but never gotten a clear response.
U/D/L/R connect as normal (like you said)
Previous responses say the 5v +/- connect up to your power source which can be:
the ipac (see the schematics).
Molex connector from the computer
or, (what I want to do, but haven't heard if this way will work or not)
a 5v transformer.
I keep getting confused as to if a ground is needed to connect up to the ipac again?
or how this is expected to work...  Anyone actually do this?  the reason I want to avoid the ipac's 5v is that I want to put 4 perfect360s on a control panel, and I'm worried about the draw through the ipac itself.  I'd feel much better pulling this from either a transformer or a molex connector. exactly how it's wired back to the ipac (just the directions? a ground? if so, from where?)
OSCAR
    • Oscar Controls
« Reply #3 on: January 14, 2004, 10:26:10 pm »
The I-PAC is grounded through the cable connecting it to the PC, and an additional GND wire is not required.  I also connected the GND from the P360's to the I-PAC ground terminals.
Oldskool
« Reply #4 on: January 14, 2004, 10:31:34 pm »
Thanks Oscar.
I plan on using the LED harness, so I guess I'm out of luck when it comes to tapping +5V from my IPAC.
I also have an Optipac. It has +5V and ground terminals for a player 2 trackball and spinner, which I'll never use.
That should work right?
OSCAR
    • Oscar Controls
« Reply #5 on: January 14, 2004, 10:36:07 pm »
Getting the +5V from the Opti-PAC should be just fine.  It is designed to run 8 optic boards, so no problems there.  From my experimenting, the Happ optic boards draw a little more power than just optoswitches alone, which is all that is in the P360 base.
