Author Topic: Hyperspin exiting favorites list  (Read 4659 times)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« on: March 17, 2016, 11:39:03 am »
I wondering if there's a simple solution and im sure there is. im using an ipac with the standard 6 button fighter setup. I configured P button to exit mame and P is also configured to exit hyperspin. my question is when the system boots into hyperspin I press Z to view favorites list, but if I want to go back into the (main list) what's the button combination? if I press P it just exits the frontend and not the fav list. suggestions
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
Nocturnaloner
  • Last login:May 05, 2016, 12:39:53 pm
  • AARRRRcade!
Re: Hyperspin exiting favorites list
« Reply #1 on: March 17, 2016, 02:14:26 pm »
It almost sounds as though it's sending a double keypress for P.  There's only one exit button, and P in your case is it.  When you press it, you should go back to your main list, then press it again to exit Hyperspin.
MAME TIME
« Reply #2 on: March 17, 2016, 02:58:26 pm »
yeah it doesn't matter what button I use to config for the exit, same deal. am I missing something?
Geometry Arcade
Neo Geo 360
MK2 standup
Nocturnaloner
  • AARRRRcade!
« Reply #3 on: March 17, 2016, 08:59:11 pm »
I don't think so.  I have noticed that when I press my ESC key, which is a wired microswitch button through an IPAC2 keyboard encoder, sometimes it sends twice, only when I am trying to exit Hyperspin, and never when I'm in a wheel.
You could try pressing your P button while clicked into a notepad document.  Try it a few times and see if it is actually sending double.  The other thing you could try is doing a button combination for exit.  That would be much harder to trigger twice in a row.
patrickfx1
  • Last login:November 29, 2023, 11:38:48 am
« Reply #4 on: October 14, 2019, 01:39:19 pm »
same for me.  i walkthrough this by assigned genre key and then it allow to choose all genre
