Author Topic: T2 arcade help  (Read 2081 times)
campbell87
  • Last login:March 16, 2016, 04:39:50 am
T2 arcade help
« on: March 14, 2016, 06:48:45 am »
Hi Guys,
I have recently purchased a T2 arcade cab in really good condition. Guns work etc and the display is good. I have a few issues that im hoping someone can help with.
The image on the screen has a slight wobble to it, you cant notice it that much when playing but it is slightly annoying.
there is slight discoloration in the screen which i assume will need degaussing? The chassis i have is a wei-ya. Not sure on the model of it as it came already in the cab
the grounding appears to be ok, i have moved the transformer to try get rid of the wobble but its not helping.
The degaussing cable, when connected to the chassis will trip the fuse :s. If i remove it then its fine.
the tube i have is a Zenith EIA 1101 25"
any help would be much appriciated.
Dan
paigeoliver
  • Awesome face!
Re: T2 arcade help
« Reply #1 on: March 14, 2016, 01:53:41 pm »
Recap the monitor and see if the degauss cable still trips the fuse and see if your other problem goes away.
Ultimately step 1 to any monitor problem is recapping it because almost every monitor problem can possibly be caps.
campbell87
Re: T2 arcade help
« Reply #2 on: March 15, 2016, 11:23:53 am »
Thank you, il give that a go. I have a wei-ya chassis, do you know what kit i could use for this?
paigeoliver
  • Awesome face!
Re: T2 arcade help
« Reply #3 on: March 16, 2016, 03:17:30 pm »
If no one sells an off the rack kit for your chassis then you have to write them down and order them individually from mouser. Wei-ya likely makes more than one model so you need the model too.
