Author Topic: Identity Crisis cab redesign  (Read 12465 times)
Pat S
  • Last login:May 23, 2005, 12:16:11 am
  • I'm not a llama!
    • Cab pics...
« on: January 14, 2004, 11:58:36 am »
I just redid my CP adding a trackball, artwork and plexi.  The template router bit made the plexi part very easy.
I couldn't have done it without the advice and info from you guys, thanks!
Before
After
Looks cool in the dark, the light strips are sound activated.
« Last Edit: January 14, 2004, 12:02:14 pm by Pat S »
fredster
  • It's all good!
Re:Identity Crisis cab redesign
« Reply #1 on: January 14, 2004, 01:42:02 pm »
Wow! I like that underlay.  Got it posted someplace for download?  If you don't you should!
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« Reply #2 on: January 14, 2004, 02:34:50 pm »
Very nice job on the cp artwork!
How do you think it would look if you used all blue buttons or 4 blue and 2 white buttons for each player?
This opinion was created from 100% post consumed information.
Stingray
« Reply #3 on: January 14, 2004, 02:51:59 pm »
Love your CP graphics!
-S
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #4 on: January 14, 2004, 03:43:31 pm »
I would if it was my artwork, but...
I learned a lot about photoshop in the past 2 weeks.  The main thing was to get the rulers set to inches so I could actually get the picture centered on the trackball.
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #5 on: January 14, 2004, 03:44:55 pm »
Good idea, my girlfriend is arguing against it, but I think it would look great, so I'll think about it for a bit.
Harakiri
  • Last login:February 13, 2014, 05:02:37 am
  • Invisible member status
« Reply #6 on: January 14, 2004, 03:45:14 pm »
Why identity crisis? Everyone "tweaks" somethings up once in a while!  ;D
It's called inovation!
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #7 on: January 14, 2004, 03:55:05 pm »
That's sweet! I do agree about the buttons though...hate the look of multi colored buttons...especially when they detract from such a clean looking panel (if you had a clown theme...maybe).
BTW...How did you get the sides lit? Is that T-molding, light tape, U/V light, or what???
Looks Great!
All Your Base Are Belong To Us!
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #8 on: January 14, 2004, 07:02:58 pm »
Looks Great!
Ha, the clown theme is killing me.
The tmolding light is el strip I got pretty cheap from here...
http://www.svc.com/lighting.html
It's about half and inch wide, and looks pretty slick even when off (at least the blue type does).
I have it hooked up to one of these things so that the light only turns on when games are being played.  http://store.yahoo.com/svcompucycle/souninwsupbl.html
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #9 on: January 14, 2004, 08:12:11 pm »
wow...that light strip is awesome.  how thick is it?  the site says it is 8mm wide, but not how thick.  and how easy is it to use?  ie. can you cut it partially to bend it edgewise?
(thoughts of a lit up CP under lexan coming to mind)
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #10 on: January 15, 2004, 05:44:32 am »
It's maybe 1.5mm tall.  That would be interesting.  They also have sheets of the stuff, though maybe not at that link.
walls83
  • beer is good
« Reply #11 on: January 15, 2004, 03:51:05 pm »
awsome cab I love it but...  I agree with the buttons maybe you could get white buttons with Blue led lights to light them up...  How good does the sound activated control work..?  Im thinking about building a StepMania machine and the light strips would look great on it.. thanks man
« Last Edit: January 15, 2004, 03:55:34 pm by walls83 »
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #12 on: January 15, 2004, 04:17:31 pm »
 :o
Wow those glow strips look fantastic!....I'm a big fan of glowing neon thingies......great job!
.....oh, but I do have to agree on the buttons.....switch out those colored ones.....your cab is so beautiful....it may be worth a little more work and a few buck to make it perfect!
The MameMaster!  8)
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #13 on: January 15, 2004, 04:22:54 pm »
Good idea about leds in white buttons.  Anyone ever see an example of this?
The sound module works great, and it has an adjustment pot on it, so you can control what level of noise sets it off, it also has an on and off switch.
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #14 on: January 15, 2004, 04:23:50 pm »
:o
The MameMaster!  8)
Thanks, ok, I guess I have to decide which color of buttons to go with now...
walls83
  • beer is good
« Reply #15 on: January 15, 2004, 04:40:17 pm »
In the main forum they had a pinned messege with the player select buttons lit up.  Same thing just you wouldnt have players on your buttons of course.  Im sure someone on this board has an example.  They looked very good though.
SirPeale
  • Green Mountain Man
« Reply #16 on: January 19, 2004, 09:45:02 pm »
That overlay is friggin' awesome.  Now you need all black buttons (including the start buttons  ;) )
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #17 on: January 19, 2004, 10:54:28 pm »
you got a website yet?  if so i want to see it, cuz im trying to make a trackball like yours and i need a little help on it.  or at least some more pics!
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #18 on: January 20, 2004, 08:58:23 am »
Dudes, no more suggestions, I can't decide what color to go with now! :)
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #19 on: January 20, 2004, 09:00:44 am »
No website.  Here's the rest of the pics I took, ask away if you have questions.
I used regular auto body bondo to fill all of the holes since I had some laying around.
Same thing for the trackball.  I used a highball zinc mounting plate from happs.  I traced the outline in the center of the panel, then routed down 1/8th of an inch, cut out the center with a jigsaw, laid it down, bondo'd the top, sanded down everything with 400 grit (used an air sander, but electric will work too).  I was going to paint it, but since it's going to be covered up, I left it as is.
I laid the CP upside down, clamped a piece of plywood underneath, and sandiwched the plexi between the CP and plywood.  Then used a router with a template bit and just dropped it into the holes, moved it around, went on to the next one.  Finally, used the same bit on the outside edges, and was done.
For the trackball hole, I had to use a hole saw.  I had no problems going slow with the drill.
I'm tempted to redo it again and move the start buttons to the sides, and redo the artwork again.  I'll probably leave it as is for a while, and maybe get some new buttons.  For the artwork I used photoshop and literally measured out the CP, found the center of the trackball, and used photoshops rulers to center the image on it.  It worked really well, I was surprised.  Then I just centered the artwork on underneath the plexi, and used a new razorblade to cut the holes out.
« Last Edit: January 20, 2004, 09:15:01 am by Pat S »
hulkster
« Reply #20 on: January 20, 2004, 08:51:05 pm »
very nice, thanks for the pics.  so what mounting plate did you get?  can you provide a link maybe? ::)  and did you just mount the big trackball harness thing underneath?  do you have any pics of the underside of your cp?
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #21 on: January 20, 2004, 09:03:52 pm »
3" Diameter Trackball with Harness, Blue Translucent with 6V Lamp
http://www.happcontrols.com/trackballs/560100xx.htm
55-1102-00   3" Clear Zinc  Mounting plate
http://www.happcontrols.com/trackballs/55110100.htm
I don't have any pics of the underside.  It's just like you said though, once you cut the hole for the trackball container, you then mount the plate, the trackball is held to it with 4 screws.
I used an optipac, but I know you can just buy a USB trackball from happs, or someone on this board was talking about using some products from Oscar Controls here... http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=15142
hulkster
« Reply #22 on: January 20, 2004, 09:25:30 pm »
preciate man!  good stuff.  one more question, i see that you got that 6v lamp with your trackball....how are you powering that?  where are you hooking up the lamp? i was going to opt for the usb blue LED.  can you explain?
Pat S
  • I'm not a llama!
    • Cab pics...
« Reply #23 on: January 20, 2004, 09:26:52 pm »
I ripped that out, and am using a led from lazerleds.com plugged into a PC molex connector.
Zakk
  • Last login:Yesterday at 05:06:16 pm
« Reply #24 on: January 22, 2004, 05:35:37 pm »
Edgedamage has wired led's into player buttons, I think he even had pics on how to get it done.  Results looks right coolio. (Check the avatar if any doubt!) :)
« Last Edit: January 23, 2004, 10:25:06 am by Zakk »
