Author Topic: Help Needed: Pole Position II not steering  (Read 3093 times)
BLACK KNIGHT
  • Last login:March 09, 2019, 08:02:19 pm
  • I'm a llama! A what?!
    • Mike's X-Arcade
« on: March 05, 2016, 10:11:14 pm »
Just thought I'd check in and see if anyone maybe knows anything about fixing a Pole Postion II arcade machine.  It was working fine one day and then I lost steering.  In test mode I don't get anything.  I checked that the wires going to the Steering PCB are supplying approx. 5v.  I also checked all of the resistors on the PCB and capicator and all appears good.  Any ideas?
  • Last login:Today at 01:04:08 pm
Re: Help Needed: Pole Position II not steering
« Reply #1 on: March 05, 2016, 11:09:36 pm »
Check that each of the two steering data lines (pins 8 and H according to the KLOV pinout here) is alternating high/low when you very slowly turn the wheel.
You may have a burned out LED or photodiode in the opto circuit.
