Author Topic: WG D9200 new chassis install won't work  (Read 2396 times)
Vincefaro
  • Last login:July 17, 2025, 11:40:56 am
« on: March 05, 2016, 12:29:13 pm »
I installed a new Chassis for my D9200 and I'm not getting picture . The Green light is on and in the neck board pcb you see this , which does not look good . I took pictures of all the connections before I took out old chassis but something is wrong . Any help?
grantspain
Re: WG D9200 new chassis install won't work
« Reply #1 on: March 05, 2016, 01:02:12 pm »
looks like neck must have a crack in it
Vincefaro
« Reply #2 on: March 05, 2016, 04:33:42 pm »
Oh Man I think I fried my video card .not a good day . I carefully put everything back oh man . Is it possible the neck board is not seeded correctly?
« Last Edit: March 06, 2016, 10:52:53 pm by Vincefaro »
Vincefaro
« Reply #3 on: March 07, 2016, 02:18:12 pm »
Can you guys check my connections. The 2 prong connector on the right side right next to the flyback goes on the neck board from the right side of the monitor correct? And then the 2 prong from the left side which you cannot see in the pic goes right nest to the power cord on the main board correct?
ed12
« Reply #4 on: March 07, 2016, 02:57:30 pm »
in your picture
that black plug (beside the flyback)
dose it go to the black coil running around the picture tube ?
or dose it hook up to the (silver wire) running around the picture tube ?
ed
obcd
  • Last login:April 03, 2019, 11:44:36 am
« Reply #5 on: March 07, 2016, 03:02:30 pm »
The one connected to the silver wire goes to the neckboard
The one connected to the black coil surrounding the picture tube goes close to the power connector.
It should even work with that connector disconnected.
ed12
« Reply #6 on: March 07, 2016, 03:19:05 pm »
obcd
if u look at the op's first picture?
u will note a perty blue neck glow.
gassie tube or false ground
look at the neck board real close
the plug beside the red wire,2pin plug
is the ground for the picture tube and the (silver wire) running around the bell of the tube
ed
Vincefaro
« Reply #7 on: March 07, 2016, 03:40:26 pm »
I will check to see which is the grey and which is the black, I think I have it right , if i do , im not sure what is causing this. Im wondering if the neck board is seeded correctly.
Vincefaro
« Reply #8 on: May 13, 2016, 03:37:05 pm »
So After taking my D9200 to a Pro to check it , The Tube is bad and therefore I will end the life of this D9200 and just take the chassis which is Brand new from Chad at Arcade Cup and call it a day. If he does not take the Chassis back from me  I will sell it to if any is interested just pm me. On a happier note since I had a feeling the Tube was bad I recently purchased a Brand New D9800 still in the box, and I will hopefully use it for my Arcade project.
