Author Topic: Hantarex Polo 25 Remote adjustment board connector & trim pots  (Read 3794 times)
basscadet
  • Last login:March 24, 2016, 04:38:52 pm
Hi all,
I have a setup that uses a Hantarex Polo 25 monitor and I'd like to make a harness to get that remote adjustment board out of the box and make it, well, remote. Thing is, I have no idea what kind of connectors I should look for. It's a 16-pin connector with flat pins (15 are actually connected). I'd also like to find some of those plastic tools on the trim pots that are missing (you can see the one in the center of the adjustment board, and there's four missing from the board at the back of the monitor screen). Any ideas?
grantspain
Re: Hantarex Polo 25 Remote adjustment board connector & trim pots
« Reply #1 on: March 06, 2016, 05:17:11 pm »
those connectors have not been available for years,some of the extender cables come up on ebay uk from time to time
a seller on jammaplus has the pot spindles,shafts-whatever you want to call them
princess prin prin
  • Last login:Yesterday at 09:45:34 am
  • intrinsically safe
« Last Edit: March 07, 2016, 07:54:29 am by princess prin prin »
basscadet
« Reply #3 on: March 10, 2016, 01:00:03 pm »
Ok thanks, I guessed those connectors would be discontinued but I thought I'd give it a try.
What's the matter with those video input pins??
Which ones?  ???
