Author Topic: Aimtrak - Mame and PCSX2 on the same cab  (Read 2209 times)
grunger106
  • Last login:November 25, 2016, 10:48:24 am
« on: March 02, 2016, 01:32:52 pm »
Hi
I've got an AimTrak gun and its working great in MAME and HOTD (PC) - and has been for 2 years
I'm now considering putting PCSX2 (with the Nuvee plugin) on my cab to play TimeCrisis2/3/CZ, since it doesn't look like MAME will support those for a while!
The documentation on this seems a little hazy and seemed to require using TopGun drivers, presumably that would screw up my working MAME/PC config?
However, the info I can find is a few years old now - is it still the case?
Thanks for any help!
« Last Edit: March 28, 2016, 12:43:08 pm by grunger106 »
TimeCrisis
  • Last login:July 22, 2023, 04:32:47 am
Re: Aimtrak - Mame and PCS2X on the same cab
« Reply #1 on: March 06, 2016, 12:06:36 am »
I play pcsx2 games with arimtrak, you just use nuvee, no topgun drivers required.
i switch between that and mame games that i use for time crisis 1, everything works really well.
grunger106
Re: Aimtrak - Mame and PCSX2 on the same cab
« Reply #2 on: March 28, 2016, 12:45:49 pm »
How exactly did you configure the plugin?
In MAME everything is fine,
However I can't get it to work reliably or properly in the PCSX2 - neither button on the aimtrack works (trigger is OK) and the calibration seems miles off whatever I do!
Any advice would be awesome :)
TimeCrisis
« Reply #3 on: March 29, 2016, 06:33:02 am »
try to mess wit the figures in nuvee, the ones with 3 numbers, like 172 etc. calibrate it by aiming at the screen at the calibration menu, that's all i can help with.
in the mean time get demul and play house of the dead 2 and confidential mission
get dolphin and use that to play house of the dead 3.
those setups should be easier.
