Author Topic: X-Arcade Tank Stick Blueprint/Diagram  (Read 11543 times)
sd_dracula
  • Last login:March 16, 2016, 10:41:46 am
« on: February 24, 2016, 11:01:47 am »
Hi guys.
Does anyone have a set of blueprints for the X-Arcade Tankstick with all the correct dimensions, hole sizes, placement etc.
Basically I am looking for this http://thydzik.com/stick/xarcade.jpg but for the tankstick.
Re: X-Arcade Tank Stick Blueprint/Diagram
« Reply #1 on: February 24, 2016, 01:07:51 pm »
Didn't find any blue prints, but Recroom Masters has an overlay that has the same dimensions.  I'm guessing you could print that out and use it as a template.
Here's a link to the page:
http://www.recroommasters.com/Custom_Die_Cut_Overlay_Skin_for_the_X_Arcade_p/cus-overlay-t.htm
Here's the template file:
http://www.xtensiongamingseries.com/Templates/Tankstick_Template_2013.zip
Hope this helps.
D
sd_dracula
« Reply #2 on: February 25, 2016, 03:16:56 am »
That is a nice start, thank you.
Would anyone know the hole diameter for the joystick and buttons on the tankstick?
jeremymtc
  • Last login:September 21, 2026, 03:09:04 pm
« Reply #3 on: February 25, 2016, 03:41:18 am »
Sticks and buttons use 1 1/8" holes.
sd_dracula
« Reply #4 on: February 25, 2016, 04:48:29 am »
Thanks.
What would be better to cut the holes with, flat wood drill bit or the circular hole saw?
  • Online Online
  • Last login:Today at 01:01:50 am
« Reply #5 on: February 25, 2016, 04:59:13 am »
Thanks.
Either of those will work, but I prefer a forstner bit like this one.  YMMV.   ;D
« Reply #6 on: February 25, 2016, 10:34:38 am »
Thanks.
If you end up using a flat bit, drill until the center part of the bit pokes through and then drill from the other side.
The edges on the surfaces will come out clean that way instead of chipping on the backside.
I also do this when using hole saws, but it isn't as necessary as long as you aren't pushing with much force.
