Author Topic: Ion lock mechanism  (Read 17412 times)
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
Ion lock mechanism
« on: February 13, 2016, 04:17:39 pm »
Hi everyone
Bought an ion that I just fixed up. Did not come with a lock. I tried installing a cam lock the same way I have on auroras but every way I try to orient the lock, it isn't catching. Does anyone know a lock I can buy or can post pictures of their locks to give me some insight on how this should work?
lilshawn
  • Moderator
Re: Ion lock mechanism
« Reply #1 on: February 18, 2016, 05:28:11 pm »
a standard 3/4" lock should work just fine. I don't have an aurora here in shop or i'd take a picture (all machines are on location) but if I recall it's possible to reassemble the locking cam in the cabinet 90 degrees out.
it will appear to work but you won't be able to lock or unlock because it's pushing the latch mechanism in the wrong direction.
I'll snap a pic if i'm out and about and one is there.
orizzle
« Reply #2 on: February 18, 2016, 06:46:49 pm »
I've replaced them in the aurora fine. But this is an ion.
The standard lock I use on the auroras doesn't seem to catch the latch.
lilshawn
  • Moderator
« Reply #3 on: February 18, 2016, 07:54:25 pm »
Oh,  the EVO.  I thought you where having issue with an Aurora.
The top lock for the board or the side lock for the cash area?
orizzle
« Reply #4 on: February 18, 2016, 10:18:56 pm »
Top lock
ed12
« Reply #5 on: February 18, 2016, 10:24:42 pm »
top lock latch sit's at the end of  the lock slider bar
u can test this your self with it open
u slide the bar 1 way it is locked slide it the other it is unlocked
shawn's lock size and barrel type is right
what u have wrong is the length of the locking :latch: bar at the end of the barrel lock its self
about 1/2-3/4"
from the edge of the barrel lock
it sits right at the edge of it
if shawn dose not up-load a pic ? i will from a evo/ion same chit
ed
mahkeymike
  • Last login:Today at 02:38:11 pm
« Reply #6 on: February 19, 2016, 12:21:55 am »
Ed12, your alive! Thought you were dead. Did you forget about this section?
ed12
« Reply #7 on: February 19, 2016, 12:24:59 am »
he he he
love u to
simulator's are open >wink/wink<
ed
mahkeymike
« Reply #8 on: February 19, 2016, 12:29:41 am »
he he he
love u to
ed
I only follow this section. I just havent noticed your name on the main forum page in awhile. Thought you were dead. Good to see that your still around.
ed12
« Reply #9 on: February 19, 2016, 12:36:33 am »
ed
lilshawn
  • Moderator
« Reply #10 on: February 19, 2016, 10:39:58 am »
this is the lock in the locked position.
it should be sticking straight out when locked. to unlock you should rotate the cylinder so the locking tab moves left (clockwise key rotation when viewed from the top.)
when you close the cover to lock it it engages the left side of the sliding mechanisim on the monitor side and the bolt sticking out of the middle of the back part of the cabinet should fit in the slot. if it's not closing all the way, you may need to back off the bolt in the middle a tiny bit.
orizzle
« Reply #11 on: February 19, 2016, 07:58:30 pm »
This worked great. Glad to have the pictures. Thank you
Sent from my LG-VS985 using Tapatalk
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
« Reply #12 on: June 05, 2016, 09:23:52 am »
I picked up two Ion Evos and they didn't come with keys.
I'd like to replace both sets of locks;  What do you recommend?
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
orizzle
« Reply #13 on: June 05, 2016, 09:39:24 am »
Go to lowes.com and search for item # 252837  - I believe this is the exact lock I used.
otsep
« Reply #14 on: June 05, 2016, 09:50:01 am »
Did you use these for both locks?
otsep
« Reply #15 on: June 05, 2016, 05:05:23 pm »
So..  How the hell to you replace the CPU Lock?  I've got it open and do not see a way to remove it.
There is a hole on one side that seems to have a button? in it.  I feel a tension release/engage, but cannot remove the bottom assembly.  Perhaps it only works if you have the correct key?
Anyone dealt with this before?
ed12
« Reply #16 on: June 05, 2016, 08:41:23 pm »
the center bottom of that lock is a philps screw
remove it
remove the latch bar
remove the nut
lock comes through the lid
ed
otsep
« Reply #17 on: June 05, 2016, 09:32:20 pm »
remove it
remove the nut
ed
The cash door lock has the phillips head on the bottom and I've already removed that lock.
This CPU lock has a flat, molded bottom.  It's the same for both of my Ions
It appears to be one molded piece, as you can see in the pictures.
ed12
« Reply #18 on: June 05, 2016, 10:18:36 pm »
u c the small slot in the middle ?
straight screw driver..
or a pair of plyers
side note: I have seen a few come in with it twisted off
ed
otsep
« Reply #19 on: June 06, 2016, 12:49:38 am »
or a pair of plyers
ed
Yep.  Tried it.
ed12
« Reply #20 on: June 06, 2016, 12:56:40 am »
well we must deduce the cover is plastic....
if u cannot get it easy way ?
2-x-drill bits down the center of the lock (top-down) works just fine
ed
lilshawn
  • Moderator
« Reply #21 on: June 07, 2016, 09:49:16 pm »
that is an unusual lock. it must be a really early cabinet. all the machines we have (20 some odd) all came with a standard "cam" lock like I pictured.
if you are looking to just replace it, just grab the golden slider part with a pair of vicegrips and twist it off. the body is just pot metal, it'll break clean off.
otsep
« Reply #22 on: June 08, 2016, 09:36:26 pm »
I got clarification from a Megatouch guy yesterday.  The lock is the factory lock for the Ion, not the Force Ion.  The standard cam locks are on the cash boxes, but the CPU locks are cam yet different.  He directly recommended against twisting it off as the bottom part(with the "slot") is a cast piece the tab locks into, as it would damage the case.  He is sending me a key with the replacement power supply I ordered for another unit.  Luckily, he said it's the same key for all Ion CPU locks and can be duped at @ Depot.
Thanks for helping me get to the bottom of it.
lilshawn
  • Moderator
« Reply #23 on: June 09, 2016, 04:39:57 pm »
wierd. is that key a L564? because yes, they are all the same... but no, it's not the same as what I have on ANY of our machines.
unless that was some kind of replacement lock for the original cam lock.
i know the setup to lock the front is a joke...so i wonder if that lock you have there was a "fix" for it.
otsep
« Reply #24 on: June 09, 2016, 04:41:20 pm »
Yeah, it's odd.  The entire lot of these Ion Evos had the same thing.  The key arrived today so at least thats working now.  Of course I've ended up with some other issues that I need to sort out.
lilshawn
  • Moderator
« Reply #25 on: June 09, 2016, 04:49:19 pm »
i'll let you know now, the purple ECS boards used in the silver ION's where absolute TRASH.
the caps powering the northbridge crap out and the ripple casues the northbridge to overheat. you can change out the caps, but the northbridge is never the same again.
sometimes you can find a decent replacement on ebay used. look for an Asus A7NBX-VM. it's a little better designed and lasts much longer than the ECS board. NOTE: you will have to modify the IO board mounting plate to clear the power connector because it's in a weird place on the board.
if you really feel like going crazy with changing the boards for something MUCH better, find some used intel D945GCLF (or GCLF2) you'll need to find a way to  mount everything in there because this board is an ITX board not ATX. this is the newest board that was used in the RX machines. as such, you will have to run at least ION system version 2009 or later. for the board to work.
otsep
« Reply #26 on: June 09, 2016, 05:04:27 pm »
I'll start a clean thread for my 2013 issues. Thanks.
mahkeymike
« Reply #27 on: June 09, 2016, 07:20:50 pm »
Hate to be that guy, but its 2009.5 or later. ;D
ed12
« Reply #28 on: June 09, 2016, 08:57:20 pm »
ditch the ecs board
go with intel
ed
otsep
« Reply #29 on: June 09, 2016, 09:08:08 pm »
ditch the ecs board
go with intel
ed
I'd love to, but one is a 2007 & the other is a 2013.  Maybe if I can find a relatively inexpensive software update for the 2007, I'll do both.
lilshawn
  • Moderator
« Reply #30 on: June 10, 2016, 12:04:08 am »
:P
2009... AND A HALF
 :lol well, if you gonna be right, better be 100% right.
otsep
« Reply #31 on: June 10, 2016, 12:05:06 am »
:P
2009... AND A HALF
Will the 2009 key work on a 2009.5 build?
lilshawn
  • Moderator
« Reply #32 on: June 10, 2016, 12:17:42 am »
yes.
lilshawn
  • Moderator
otsep
« Reply #34 on: June 23, 2016, 11:13:25 pm »
Yep.  I knew I wasn't crazy.  I was trying to remove the cam before I had a CPU key.
The trick here is that the bottom half doesn't come out and you have to replace the tumbler set.  Good stuff.
