Author Topic: How to fake PC header connections?  (Read 1893 times)
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
« on: February 12, 2016, 11:54:10 am »
Hi
I'm currently putting together another MAME rig from a de-cased PC, but the BIOS is detecting that the front panel USB 2.0 ports and audio jacks aren't connected to the headers on the motherboard. This is annoying, as I then have to press F1 to continue booting into windows.
So, the question is, how can I fool the BIOS into thinking the header cables are connected? Presumably I just need to short certain pins? Below are the pinouts of the headers I'm talking about.
Thanks.
Re: How to fake PC header connections?
« Reply #1 on: February 12, 2016, 12:45:58 pm »
anything stopping you from ripping the front panel out of the case, and just plugging it in without using it?
DudeRegular
« Reply #2 on: February 12, 2016, 12:48:37 pm »
Also poke around in the bios for a setting along the lines of halt on error.
Sent from my LGLS990 using Tapatalk
big10p
« Reply #3 on: February 12, 2016, 01:20:20 pm »
I want to keep the case intact, as I plan on using it in the near future.
I looked at the Halt settings in BIOS, but they can't be turned off. The only 2 settings are 'All' and 'All, but keyboard'.
I think I'll get the multimeter out and see if I can figure out which pins get connected by the header cables.
Cheers.
ed12
« Reply #4 on: February 12, 2016, 01:25:14 pm »
pin 7 to gnd
or to high,whichever it likes
that is your sense line
ed
big10p
« Reply #5 on: February 12, 2016, 03:54:58 pm »
Thanks, ed12. I connected pin 7 to pin 4 (3.5v) and that's sorted the audio detection. Not even sure how this works TBH, as there's no continuity (or resistance) between those pins, on the cable. I could only read continuity between pins 1 and 3. Hmmm.
Anyway, I also sorted the USB detection by connecting S-GND to GND, which is what the cable was doing.
Cheers all.
