Author Topic: Mame directdraw vs. direct3d / direct3d9ex for Windows 7? Upgrade questions.  (Read 3504 times)
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
I'm looking at the possibility of upgrading my cab from Windows XP x86 to windows 7 x64 now that the new crt_emudriver with support for newer cards has landed.
What I would like to know is: on XP it was generally recommended to use directdraw from what I was seeing. I've had it running that way very well for most games with good performance, so I didn't mess with it. What do people recommend with Windows 7?
I mean, for Windows 7 I see that direct3d is *usually* recommended due to Windows 7 performance issues with directdraw. But you must use a framedelay setting to avoid input lag. Is that per game though? That seems a little annoying if so, playing through every game to figure out the right input lag...is it as big a deal as I think? Is it worth the trouble vs. using directdraw?
How well does d3d9ex work for people?
Are there any other options I should be considering? For what it's worth I never had to make custom resolutions under XP, I used the arcade_15 preset with a slightly tweaked modeline (reduced the max vertical pixels so more vertical games fit) and went from there. It looks like I might have to make some magic and/or super resolutions (still a little unclear on that) from what I've been reading.
Any thoughts or information is very welcome!  :)
« Last Edit: February 04, 2016, 01:04:41 pm by burn_654 »
Calamity
  • Moderator
  • Last login:Today at 07:23:05 am
  • Quote me with care
d3d9ex works just like ddraw lag-wise. Because there's no frame queue, the use of frame delay is up to you, to remove the last remaining frame of latency.
Steps to create a log:
burn_654
That's good to know. Given that I was satisfied with directdraw's input/general performance I'll be checking out d3d9ex if I move my system over to Windows 7.
Other things are up in the air before I can do that but just wanted to understand the new elements a bit better. Thanks calamity!
