Author Topic: Frame delay and tearing on a CRT  (Read 7466 times)
Foxhole
  • Last login:May 09, 2025, 05:02:07 pm
« on: January 31, 2016, 03:36:54 pm »
Hi, i seem to be having a problem with the frame delay feature.
Whenever i set the frame delay above 5 i get some static tearing on the upper side of the screen.
It's a crt screen with crt emudriver 1.2b and super resolutions, win7 x64.
The video mode is ddraw, could that possibly be the problem?
As far as i know this problem only happens with LCDs and high resolutions.
On my main pc with the lcd i get that screen tearing no matter which frame delay i choose.
On my main pc i tried playing around with the vsync offset setting, didn't do much help but change the location of the tearing.
On the crt emudriver pc i didn't play around with the offset since from what i understand that shouldn't happen in the first place.
I should also mention that i am currently using gm asio, but it also happens with the regular groovymame.
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   ..\..\roms\mame
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     0
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     1
skip_gameinfo             1
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
http                      0
http_port                 8080
http_path                 web
console                   0
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   custom
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              2
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                15200-15700, 49.95-62.00, 2.500, 4.634, 6.780, 0.064, 0.160, 1.056, 0, 0, 192, 288, 448, 576
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
asio_log                  0
asio_device               0
asio_cal_freq             0.0
# OSD FONT OPTIONS
uifontprovider            auto
# OSD DEBUGGING OPTIONS
debugger                  auto
watchdog                  0
# OSD PERFORMANCE OPTIONS
multithreading            1
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     ddraw
numscreens                1
window                    0
maximize                  1
keepaspect                0
unevenstretch             0
waitvsync                 0
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                2560x0
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD SOUND OPTIONS
sound                     auto
audio_latency             1.0
# WINDOWS DEBUGGING OPTIONS
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  1
profile                   0
# WINDOWS VIDEO OPTIONS
prescale                  1
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
filter                    0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_preset               -1
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_alpha         0.0
shadow_mask_x_count       320
shadow_mask_y_count       240
shadow_mask_usize         0.09375
shadow_mask_vsize         0.109375
curvature                 0.03
pincushion                0.03
scanline_alpha            1.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   0.0,0.0
converge_x                0.3,0.0,-0.3
converge_y                0.0,0.3,-0.3
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     1.570796325
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        0.3
raster_bloom_scale        0.225
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.21
bloom_lvl2_weight         0.19
bloom_lvl3_weight         0.17
bloom_lvl4_weight         0.15
bloom_lvl5_weight         0.14
bloom_lvl6_weight         0.13
bloom_lvl7_weight         0.12
bloom_lvl8_weight         0.11
bloom_lvl9_weight         0.10
bloom_lvl10_weight        0.09
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
dual_lightgun             0
intealls
  • Last login:May 07, 2026, 02:57:43 pm
Re: Frame delay and tearing on a CRT
« Reply #1 on: January 31, 2016, 03:46:27 pm »
First of all, frame_delay should be used as a per-game setting. The ASIO build has a benchmark that can help you deduce what frame_delay setting your PC is capable of running the game with. It should not be used as a static setting, since the drivers vary very much in speed.
What game are you running? Or does it tear with all games you've tested?
Foxhole
« Reply #2 on: January 31, 2016, 03:56:00 pm »
Basically i set the frame delay to 7 for the most part since my pc can run most games with that setting, while the games that are more demanding get a specific frame delay setting in a separate ini, is that a problem? Everything runs 100% speed that way.
It tears with every game that i tested, unfortunately.
I care mostly about the crt emudriver pc (Emulation pc) and not my main pc.
On my emulation pc i do set the frame delay game by game since it's a slower pc than my main one.
Calamity
  • Moderator
  • Last login:May 27, 2026, 05:38:56 pm
  • Quote me with care
« Reply #3 on: January 31, 2016, 04:05:15 pm »
Hi Foxhole,
A super resolution is indeed a high resolution. You said you're on CRT Emudriver 1.2b, I understand you must be using a card from the HD 4000 family. Your card is probably struggling with the scaling required. This only gets exposed when frame delay is enabled, because this feature requires the whole gpu processing to happen in a fraction of the frame period. I know what you're thinking: wasn't super resolutions the way to go with Windows 7? Yes, it is. But frame delay is an experimental feature, and general assumptions surrounding MAME don't fully apply here. One such assumption is gpu power doesn't matter with MAME. It turns out it does matter with frame delay enabled, because the faster the gpu processing is done, the most reliably frame delay will work. I've noticed how my cheap HD 6450 card behaves better on this regard than any previous HD 4000 card I've tested.
Anyway, you should not be using DirectDraw unless you have a very good reason. DirectDraw is known to be slower.
Steps to create a log:
intealls
« Reply #4 on: January 31, 2016, 04:08:18 pm »
The problem is that if the PC is not capable of running the game with the specified frame_delay, tearing will be unavoidable. But I've only tested this with d3d, I don't know how it works with ddraw.
Ok, thanks for reporting, then please try using d3d (not d3d9ex, regular d3d seems to work better with CRT Emudriver 1.2b). Also vsync_offset will only affect d3d/d3d9ex.
Edit: Calamity was faster. :)
Calamity
  • Moderator
« Reply #5 on: January 31, 2016, 04:24:13 pm »
In order to know the source of the problem, create a normal resolution to run a sample game, say 320x240, and apply frame delay with it.
Foxhole
« Reply #6 on: January 31, 2016, 04:35:51 pm »
I'll try that.
I should also try changing the video mode, but i'm kinda confused now.
If i set the video mode to d3d i have to set the frame delay to 1, right? to fix the flip queue.
Wouldn't that be slower than ddraw with frame delay of 0?
So what should be the best option for me?
Video card: HD 4350
Calamity
  • Moderator
« Reply #7 on: January 31, 2016, 04:38:27 pm »
You use the same values for any API. The frame queue is bypassed by any value greater than 0.
Foxhole
« Reply #8 on: January 31, 2016, 04:50:17 pm »
What i mean is, d3d is faster than ddraw, but if i don't use a frame delay of at least 1 i'm going to get input lag due to the flip queue.
So what i'm trying to understand is, what is faster, d3d with a frame delay of 1 or ddraw with a frame delay of 0?
intealls
« Reply #9 on: January 31, 2016, 05:06:41 pm »
With frame_delay set to 1 you're always going to sacrifice 1/10 of frame time of processing power due to throttling, which would otherwise be used for emulation, it probably won't matter for most games.
@Calamity
Does your multithreading implementation square off other performance differences related to ddraw/d3d?
Calamity
  • Moderator
« Reply #10 on: January 31, 2016, 05:09:01 pm »
Speed and latency are different categories. D3D is always faster, but has more input latency if you don't use frame_delay. D3D9ex without frame_delay is as fast as D3D and has as low latency as DirectDraw.
Calamity
  • Moderator
« Reply #11 on: January 31, 2016, 05:11:05 pm »
@Calamity
As long as syncrefresh is used, the video part behaves the same as when single threaded. It's the input processing what may see a marginal benefit.
Foxhole
« Reply #12 on: January 31, 2016, 05:48:39 pm »
So i tried several combinations.
Super resolution + D3D/9ex + Frame delay 6 or 7 = Static tearing
Normal resolution + D3D/9ex + frame delay 6 or 7 = No tearing
Normal resolution + DDraw + frame delay 6 or 7 = No tearing
So yes, the card isn't fast enough for the super resolution, i guess. :\
Any recommendations for a better card?
Also tested ddraw vs d3d/9ex, and d3d indeed was faster.
Is there even a point using d3d and not d3d9ex?
intealls
« Reply #13 on: January 31, 2016, 06:06:23 pm »
I seem to recall d3d providing better ASIO performance with high frame delay values on 1.2b, but this may be machine specific. If there's no difference on your machine there's no reason not to use ex.
Have you tried to get rid of the tearing with vsync offset?
Edit: Never mind, this would be equivalent of lowering the frame delay value.
« Last Edit: January 31, 2016, 06:11:44 pm by intealls »
Foxhole
« Reply #14 on: January 31, 2016, 06:08:11 pm »
I will try that later on.
EDIT: Then i shall not try that.  :P
« Last Edit: January 31, 2016, 06:28:58 pm by Foxhole »
intealls
« Reply #15 on: January 31, 2016, 06:46:33 pm »
Does the tearing position move between fd6/fd7 and super resolutions? Does it tear with fd1? If it moves and/or does not tear with fd1, would you mind doing a quick benchmark with the games you're testing, namely to run each of them with -bench 180, and report what the 'Frame delay/percentage:' line near the end of the log reports? The thing is, you may be hitting the present code _very_ late. This would indicate that you're using a frame_delay setting which is a bit too high, and this needs to be ruled out. Are you getting 'missed retrace' entries in the log (needs to be run with -v)?
Are you using the same games to test, Bad Dudes/Ninja Masters/Comix Zone/SFA?
On my GM rig the maximum fd setting I can use with SFA is 7, Comix Zone 6 and Ninja Masters 8. How fast is your emulation PC?
Yeah sorry about that. :)
« Last Edit: January 31, 2016, 06:49:33 pm by intealls »
Foxhole
« Reply #16 on: January 31, 2016, 07:24:51 pm »
I'll need to test again to give you an answer about that.
It does not tear with fd1, i'll try the bench and let you know.
Foxhole
« Reply #17 on: January 31, 2016, 07:51:07 pm »
The emulation pc with the d2x is actually isn't that fast. It's a quad core q8200 oc'ed to 2.9Ghz.
The one with the audigy 4, with the kx drivers, is in fact the faster one, I5-4570 3.2Ghz, and that's the one with the crackles, lol.
I tested the game cybattler with fd6 and 7, and it doesn't look like the tearing position moves, but on fd7 it's more visible.
I also used bench on the game. I've included 3 logs, the bench, fd6 and fd7.
Foxhole
« Reply #18 on: February 01, 2016, 05:24:06 pm »
As for my pc with the lcd, If i can remove the tearing using the vsync offset setting, do i really need to lower the frame delay?
Setting vsync_offset to 110 seems to remove the tearing for most games i've tried, but according to this i also need to lower the frame delay:
Notice that you'll need to lower your frame_delay value proportionally to the amount of lines you set in -vsync_offset.
Is it really necessary to lower the frame_delay even though i can remove the tearing without doing so?
« Last Edit: February 01, 2016, 05:26:36 pm by Foxhole »
