Author Topic: Adding 2nd xin mo 2 player controls  (Read 2835 times)
Duhjoker
  • Last login:August 29, 2016, 08:03:00 pm
« on: January 31, 2016, 04:58:32 am »
Well it ive got my cocktail cabinet pretty much completed after adding 2 extra buttons to each six button console and mala works great.
   But i need to add 2 possible 3 more buttons so each side has a start and a select button plus i would like to add my coin mech up too so it works and an emu quit button dedicated.
Only problem is im pretty much out of pins for wiring. What i want to know is if i buy another 2player xin mo if the emus and mala will use both control hubs at once.
JDFan
Re: Adding 2nd xin mo 2 player controls
« Reply #1 on: January 31, 2016, 06:26:58 am »
Yes -- each will be seen as a different game pad - so should not be a problem to have 2 of them in the 1 system. That said How many buttons are you using total ?? With 30 inputs on the Xinmo there should be more than enough for a 2 player setup if done properly ( 2 joysticks take 8 leaving 22 for buttons so even if an 8 player button setup that leaves 6 admin butttons fo player 1 and 2 start and coin buttons and 2 for pause and exit ) and then if additional buttons are needed you can use the extended mappings (see below) to get a few more using impossible multi inputs (ie. cant normally press both up and down on a single joystick so can use that combo press as an admin function input)
Degenetrons posted some directions on extended mappings for the Kade encoder which can also be used for the Xin mo -  HERE ( https://sites.google.com/site/degenatrons/controller-interfaces/usb-keyboard-encoder/resources ) - Main thing is to use button combos for the admin buttons that are not going to be input together while in game like Joystick 1 up and joystick 1 down.
    Extended Mappings (Advanced)
    The extended mapping groups provide support for more buttons by making use of key combinations that are not possible via the arcade controls.
    There should be no conflicts e.g. it is not possible to move joystick up and down at same time.
    The 5th and 6th buttons for player 2 are not defined as MAME defaults so you will need to update the config or you could add 2 extra buttons to player 1.
    These keys and key combinations should be defined in your MAME configuration when using this extended mode.
     Key Combination                  Description
     Up Arrow + Down Arrow            P1 Start
     Left Arrow + Right Arrow            P1 Coin
     R + F                                    P2 Start
     D + G                                    P2 Coin
     Up + Down + R + F                    Cancel (Esc)
     Enter                                    Select and also P1 Button 6
     C                                            P2 Button 5 (or P1 Button 7)
     V                                            P2 Button 6 (or P1 Button 8)
« Last Edit: January 31, 2016, 06:29:55 am by JDFan »
Duhjoker
« Reply #2 on: January 31, 2016, 04:07:19 pm »
Well i have 1 joystick for each side and 9 buttons. A 1 player start button and 8 regualr buttons for play. I still a single button for each side as a select button then i need a way to add my coin mech and a dedicated button to exit emus (other than mame) back to mala.
paigeoliver
  • Awesome face!
« Reply #3 on: January 31, 2016, 11:08:36 pm »
What games are you running that have a cocktail mode that have more than 3 buttons?
Duhjoker
« Reply #4 on: January 31, 2016, 11:13:54 pm »
Some capcom games,streetfighter games and such.
Duhjoker
« Reply #5 on: February 01, 2016, 02:05:03 am »
Looking at the map that came with my X in more and I see it says none on pin 18 on the p1 side, can this pin be used?
paigeoliver
  • Awesome face!
« Reply #6 on: February 03, 2016, 12:42:10 pm »
Ah, I for some reason thought it would be a traditional cocktail where the people sat across from each other.
Duhjoker
« Reply #7 on: February 04, 2016, 12:59:17 am »
Yea thats it like you said just a regular cocktail cabinet where 2 players play head to head. Plus a few emulators just for games on older systems that i never got to play for my own amusement. Main mode is classic arcade games from the OG to mid 90's.
I wish i could play some of the emus in split screen but nobody has made anything that i could find to split a window and double it. Which kinda bothers me. Console emulation has been around for a while now and nobody has fixed this problem? Wuwt?
Heres a pic.....
Just got done setting marvel vs capcom to split and h to h and for both players
Gonna build a better console soon, we made to unscrew off, just have to go around the top edges with a razor, The bottom and sides will be hidden by the wider console.
« Last Edit: February 04, 2016, 01:53:36 am by Duhjoker »
