Author Topic: Decasing a PC CRT monitor  (Read 1844 times)
Don
  • Last login:March 26, 2024, 04:39:03 pm
« on: January 24, 2016, 03:00:30 pm »
I am trying to decase a 21" PC CRT monitor for my arcade build but i'm having some difficulties. I have removed the back and the stand but I cannot get the front bezel off. It was attached to the chassis by four corner bolts which I have removed, but it is still being attached somewhere around the front control buttons area.
Does anyone have experience decasing a PC CRT? And was there some extra attachment I cannot see at the front controls?
« Last Edit: January 24, 2016, 07:56:37 pm by Don »
Slippyblade
Re: Decasing a PC CRT monitor
« Reply #1 on: January 24, 2016, 03:05:37 pm »
Wow, that's a hell of an encasement.  I'm assuming that metal grid is pretending to be a Faraday Cage to keep EMF emissions down.  Can't help ya here, just commenting and subbing cause I wanna use a PC CRT in my cocktail.
« Reply #2 on: January 24, 2016, 04:53:31 pm »
They're all different. Just look around carefully for smaller screws or cables. Do not simply yank it off - you might risk breaking the controller board on the front of the monitor.
Alejo I
  • Last login:Today at 06:30:09 pm
  • Trying something new
« Reply #3 on: January 25, 2016, 08:27:46 am »
Look for the service manual on Google. You can easily find the instructions to decase most modern monitors on the interwebs (as I learned myself trying to fix a Trinitron unit not so long ago).
cj138
  • Last login:May 23, 2018, 06:56:39 pm
« Reply #4 on: January 25, 2016, 11:12:40 am »
I have decased 2 19" monitors and not had to deal with that big metal cage.  I think it is typical for 21" monitors to have those.  I recently picked up a 21" and if I use it, I probably won't bother decasing it. I will probably make a decent bezel and hide it behind smoked plexi....
