Author Topic: Pcsx2 full screen  (Read 3418 times)
androtaz08
  • Last login:October 09, 2024, 07:17:01 am
Pcsx2 full screen
« on: January 22, 2016, 11:06:35 am »
Anybody have any success running pcsx2 on their crt? The problem I have is that it doesn't seem to switch resolutions only run at the desktop resolution. I have set the internal resolution to native but when I go to full screen it runs at 800x600. Every other emulator besides pcsx2 and 4do can change full screen resolutions. Any ideas?
R-Typer
  • Last login:September 09, 2024, 12:50:41 pm
  • C64 Rulez!!!!
Re: Pcsx2 full screen
« Reply #1 on: January 22, 2016, 11:28:04 am »
This is because PCSX2 uses desktop resolutions. It does not switch resolutions like other emulators.
I use ArcadeOSD to switch desktop resolution to 640x480@60hz and then I start PCSX2. To get fullscreen I double click on the PCSX2 window. This is for NTSC games.
Of course you can run PAL games in 768x576@50hz if you prefer.
If you mix PAL and NTSC games you will get screen tearing.
« Last Edit: January 22, 2016, 11:33:15 am by R-Typer »
androtaz08
« Reply #2 on: January 22, 2016, 11:44:20 am »
Thanks. That's what I'm doing now but I didn't know if there was a way to automate the process using rocket launcher, or something else.
