Author Topic: VMMAKER - Freezes  (Read 1723 times)
philexile
  • Last login:October 30, 2022, 03:45:01 pm
  • I want to build my a GroovyMame PC!
VMMAKER - Freezes
« on: January 09, 2016, 06:56:03 pm »
Hello,
Whenever I try to load an INI with VMMaker without generating modelines from Mame, the program crashes. Please see the image below:
I've also tried to delete the modelines from the driver, but that also freezes the program and I have to hard reboot. When I do, none of the new modelines have been installed.
Could you please advise?
Thank you
Sledge
  • Last login:July 24, 2025, 09:26:13 pm
Re: VMMAKER - Freezes
« Reply #1 on: January 09, 2016, 08:43:58 pm »
Something very similar happened to me too, but only once.
Left it for a while, and nothing happened, so i rebooted PC and there was no driver present...
Reinstalled driver, and everything was ok.
How many times did you try to do this?
Calamity
  • Moderator
  • Last login:July 19, 2025, 04:03:33 am
  • Quote me with care
« Reply #2 on: January 10, 2016, 03:54:47 am »
Please download beta 5. I added a delay to avoid this problem (not documented in the change log).
Basically when restarting the device the program first turns it off, then it turns it on again. I added a delay in the middle. If this keeps causing problems I'll need to make this feature optional, and go back to the continuous add-modes->restart hell cycle. This is only needed for legacy cards however.
Sledge, if you see the issue again, instead of reinstalling the driver, go into device manager and re-enable the video card manually.
Steps to create a log:
haynor666
  • Last login:July 25, 2025, 04:09:52 pm
  • retro maniac
« Reply #3 on: January 10, 2016, 07:47:33 am »
It's fixed - I installed couple time different modelines and VMMaker always after some time correctly resets video card.
philexile
« Reply #4 on: January 10, 2016, 12:13:04 pm »
I reinstalled the driver, along with beta 5 and that resolved the issue. Thanks!
