Author Topic: OpenGL Died in Crt_Emudriver 2.0 beta  (Read 4209 times)
emubastard
  • Last login:October 18, 2018, 07:10:57 pm
  • I met your mom once, she looked like Ms. PacMan!
    • Emubastard
« on: December 30, 2015, 10:53:16 pm »
When I try to run any opengl program I get a dialog box that says...
"LoadLibrary failed error 87: The parameter is incorrect."
Searching online suggested to rename "atig6pxx.dll" to "atig6pxx.dll.bak" in C:\Windoiws\System32 but that didn't fix anything.  Both GL apps just crashed with no error message then.
Retroarch crashes with this error when the video driver is set to gl
I also downloaded a simple GPU Benchmark which also gives the same error.
http://www.geeks3d.com/20130419/gputest-0-3-0-cross-platform-opengl-benchmark-for-windows-os-x-and-linux-released/
When I ran the new vmmaker, it also removed my directdraw setting in my mame.ini, which if I am not misinformed, is still better in Windows 7???
I can get retroarch to 1.2.2 to work with the d3d driver, but the damn thing crashes everytime you exist, that's why I was using the gl driver, that worked fine.
-Bastard
-Bastard
haynor666
  • Last login:September 14, 2026, 03:38:01 pm
  • retro maniac
Re: OpenGL Died in Crt_Emudriver 2.0 beta
« Reply #1 on: December 31, 2015, 03:43:00 am »
I wonder if this error is related to my problems with certain Taito Type X games  ???
Calamity
  • Moderator
  • Last login:Yesterday at 07:35:09 am
  • Quote me with care
« Reply #2 on: December 31, 2015, 05:47:35 am »
Confirmed.
I've uploaded beta 2 version with fixed OpenGl support, the OpenGL benchmark tool now works here, haven't tested anything else. Thanks for reporting!
Steps to create a log:
haynor666
  • retro maniac
« Reply #3 on: January 01, 2016, 05:27:09 am »
Seems to be a problem for certain Taito Type X games as well, thanks Calamity.
haynor666
  • retro maniac
« Reply #4 on: January 06, 2016, 01:19:48 pm »
Calamity, is OpenGL ok in beta 4? Daphne using opengl right now crashes.
Calamity
  • Moderator
« Reply #5 on: January 06, 2016, 02:19:13 pm »
Did it work before?
haynor666
  • retro maniac
« Reply #6 on: January 06, 2016, 03:00:10 pm »
Yes, it worked but only with previous driver 13.1. Didn't work with any beta.
EDIT.
Ok, Now I know why it worked in previous windows 7 installation - because I had previously installed 13.1. I simply removed 13.1 and start testing betas. On fresh installed system I started testing from beta 2.
I installed now 13.1 - daphne working.
Uninstalled 13.1 - didn't work.
Installed back 12.8 - daphne working.
Probably some files are missing in new drivers.
« Last Edit: January 06, 2016, 03:09:12 pm by haynor666 »
Calamity
  • Moderator
« Reply #7 on: January 06, 2016, 03:29:43 pm »
Thanks haynor666, good information. Indeed CRT Emudriver 2.0 is based on Windows default drivers which are a stripped off version. I'll need to re-add files.
