Author Topic: .  (Read 3312 times)
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« on: December 27, 2015, 10:23:26 pm »
« Last Edit: February 01, 2016, 09:35:15 pm by brad808 »
grantspain
Re: looking to do tube swap
« Reply #1 on: December 28, 2015, 03:08:15 am »
doutful as i am sure the inductance does not match
brad808
« Reply #2 on: December 28, 2015, 04:57:57 am »
« Last Edit: February 01, 2016, 09:36:32 pm by brad808 »
grantspain
« Reply #3 on: December 28, 2015, 06:09:25 am »
you need an inductance meter and read the same way as for impedence
i know the d9400 is 0.240mh and I am sure the kt29xx are 0.300mh
plus the d9400 is pure flat crt and the kt29xx are semi curved
it will probably work but you will get unfixable geometry issues
brad808
« Reply #4 on: December 28, 2015, 06:29:43 am »
« Last Edit: February 01, 2016, 09:37:54 pm by brad808 »
grantspain
« Reply #5 on: December 28, 2015, 07:32:14 am »
Ok I won't bother if there will be issued. The d9400 I have is in fact a curved monitor not flat.
i have only seen one d9200 curved and never a d9400 so it must be quite rare
you should consider asking Chad at arcadecup whether he thinks they may match ok
brad808
« Reply #6 on: December 28, 2015, 03:48:45 pm »
« Last Edit: February 01, 2016, 09:41:57 pm by brad808 »
brad808
« Reply #7 on: December 28, 2015, 09:03:18 pm »
« Last Edit: February 01, 2016, 09:36:52 pm by brad808 »
brad808
« Reply #8 on: December 30, 2015, 10:05:30 pm »
« Last Edit: February 01, 2016, 09:37:04 pm by brad808 »
grantspain
« Reply #9 on: December 31, 2015, 05:37:20 am »
you are brave to have done this but looks as if you may have found a good match
you may be able to counter the low contrast by a number of routes,
first use the RGB option in the menu to adjust each colour gain and cut off
i think there is a factory menu option but i can't remember how to access this on the 9400,it will be a combination of two buttons on the remote board-this will allow you to get a wider range of adjustment on the contrast etc
the issue could be a mismatch on the heater current,there is a adjustment pot that is sealed on the main chassis-this may sort out the issue but i have never adjusted this pot before so i do not know what will happen
brad808
« Reply #10 on: December 31, 2015, 08:43:30 am »
« Last Edit: February 01, 2016, 09:37:17 pm by brad808 »
grantspain
« Reply #11 on: December 31, 2015, 12:15:57 pm »
hv adjust that is,shouls not adjust that
http://www.wellsgardner.com/pdf/Board/D9400.pdf
brad808
« Reply #12 on: December 31, 2015, 12:31:26 pm »
« Last Edit: February 01, 2016, 09:37:26 pm by brad808 »
grantspain
« Reply #13 on: December 31, 2015, 01:10:28 pm »
yep
