Author Topic: Rockola 450  (Read 2401 times)
pattit
  • Last login:December 21, 2015, 12:19:10 pm
Rockola 450
« on: December 21, 2015, 12:18:27 pm »
I have a Rockola 250 that works fine until the end of the record. The tonearm does not lift automatically and I have to lift it by hand. It works fine after that but it is a real pain to have to manually pick it up. Any suggestions would be greatly appreciated. Thanks!
whammoed
  • Last login:Yesterday at 10:23:48 pm
  • Crack don't smoke itself
    • NiceMite
Re: Rockola 450
« Reply #1 on: December 27, 2015, 07:36:27 pm »
Make sure it is triggering the end of play switch.  What happens when you hit the cancel button next to the volume knob on the back of the jukebox?  Does it work then?
Also you may want to consider doing a counterweight mod to your tonearm.  Won't help this issue but it will be better for your records.
http://nicemite.com/Jukebox/Jukebox.htm
