Author Topic: Using 8 liner chassis w/ nintendo PCB  (Read 1168 times)
Pipercub
  • Last login:December 08, 2009, 10:59:48 pm
  • My living room is a F'n arcade
    • Subaru Brat
« on: January 11, 2004, 09:12:06 am »
I know the NEC nintendo monitors can be set to inverted or non-inverted to work with standard or Nintendo output. I am looking to go the other way, using a standard monitor with the NES output. Can I just use the seperate inverter board from the NEC monitor to invert the signal? I assume that the sync and RGBs need to be inverted?
(This is for a Playchoice10)
