Author Topic: Mame + Motors + Punch/Fighting mania. What should i do to hook?  (Read 3883 times)
TreX
  • Last login:February 20, 2022, 12:34:45 am
« on: December 18, 2015, 08:19:33 pm »
Hellou arcade community.
This is the standart first post^^. I am not a native english speaker but i will try to do my best.
I woke up today with the idea to build a Punching Mania simulator. Sadly i could not find a similar topic on the whole internet.
It`s my first time with mame but not the first project on building special input devices. I also have some skills in game development and a basic understanding of Hardware.
How far am I (not very far):
 I got the roms to run with mames last build... somehow. (no sound on Fightingmania befor upgrade to punch and some weird bugs with autofire on some mame builds).
What I want:
To play the game you have to hit the paddles wich are coming at you when the led lights on the paddles are on.
I think the process is something like.
-->Turn Motor on(I think the game can read the position of it 0....255)
-->when motor/paddle reach position 255--> light up the led. (maybe there is a switch to signalize the fuly extended paddle)
-->(decrementing healt if no reaction)
--> on hit, the game gets a simple button press input.
--> retracting the paddles
--> If paddles are blocked and/or you dont hit them in time you get a MISS
--> Paddles auto retract
Now the big BUUUT
Mame has a some shortcuted procedure.
The states are indicated buy a simple string.
Like  (555*50)
5 = paddle is ready
* = led on(ready to hit)
0 = paddle retracting???
The motors are going from 0 to 255 in a blink of an eye and so you have a to little  time to react after the led goes on.
If you hit or miss Motors are going to 0
When i tried to read the outputs with  Mame Hooker I just got the Paddle LEDs and the Selection LEDs
But I want the motor signals and the ability to make this 0...255 inputs or at least 2 different states(motor min and motor max) that i am giving to the game mechanicly and not from  mames auto pilot.
I think I have to compile mame with some addditional own code. But since i dont worked with mame i dont know where those changes where(or should be) made by the developers(i am pretty sure they simulated the motor inputs in mame). Next i will need some hooks for mame hooker and at least 6 more buttons for the game^^.
Where do I start what is the proper way^^.
and btw how  do I get rid of autofire.
If there is someone who can provide any information on the cabinet mechanics or the game itself I would be very happy.
Thx
TreX
« Last Edit: December 18, 2015, 08:27:04 pm by TreX »
  • Last login:Today at 05:03:51 am
Re: Mame + Motors + Punch/Fighting mania. What should i do to hook?
« Reply #1 on: December 18, 2015, 09:45:24 pm »
Welcome aboard, TreX.   ;D
It looks like a really complicated controller build if you try to do moving target paddles like the arcade version.
Seems like it would be much easier to use fixed targets since this is your first build.   :dunno
Howard_Casto's MameHooker program should allow you to hook up the lights on the targets if you don't want the on-screen fist indicators. (0:41 and 2:20 in this video)
http://youtu.be/HSp9IiQEwAw?t=140
TreX
« Reply #2 on: December 18, 2015, 10:39:03 pm »
Thank you for the fast reply.
I dont think that it is very complicated maybe somehow expensive if i would use my prefered parts. So yes like you where saying i will build a static prototype first, then maybe a springloaded one(fully moving but no motors required) in which you use the "punch" to load the springs and a simple relais to let the paddles go.(not very suited for this game cause you will need a little bit of "power" in every hit). Dont wory i have some skills in crafting wood and iron and circutery.
And if i get a glimpse how the real arcade works i will recreate it somehow.^^
But first is first i need that damn game logic and the outputs. ;D
In that Video of yours I can see that the game outputs the signals wihout the "real" motor/pad motion delays but it would be enough to start to build the static and the springloaded one...
And again the big BUT thing:
...but i dont know how to get all the states out of the game to MameHooker the only one i can get out are the LEDs. I need at least 6 more for pad ready status (and optional 6 for pad closed) represented buy the 0 and the 5
I even think that the "pads ready" triger is trigering the LEDs on the pads
This is what i can get out with Mame Hooker:
Code: [Select]
Emulator=MAME
Game Info:
Rom=pnchmn2
Parent=pnchmn2
Driver=
Orientation=0
Outputs:
12348=select left right=0
12349=left bottom lamp=0
12350=left middle lamp=0
12351=start lamp=0
12352=left top lamp=0
12353=right middle lamp=0
12354=right top lamp=0
12355=right bottom lamp=0
only the lights.
I will post the debug menu from the Cabinet after a little breake.
I think my first question would be where do i have to "hack" to have influence on the on screen fist indicators? I think it would be somwhere deep in MAME or is it in the ROM or BIOS?
« Last Edit: December 18, 2015, 10:41:19 pm by TreX »
« Reply #3 on: December 18, 2015, 11:17:10 pm »
Can't verify with my version of MAME, but try this:
- Launch the game
- Press Tab to bring up the menu
- Select the Video Options menu
- There will probably be several options at the top (Upright Artwork, Standard 4:3, Cocktail, etc.)
- Select "Standard 4:3" -- That should give you the regular arcade monitor display without the fist overlays.   ;D
TreX
« Reply #4 on: December 19, 2015, 06:39:06 pm »
Sry but it is not working.
Also it was not what i wanted to achieve.
I found the part where i can start from. Its this file -->mame\src\mame\drivers\ksys573.cpp
Somwhere here are the controlls for the I/O i supose:
Code: [Select]
/* punch mania */
ADC083X_INPUT_CB(konami573_cassette_xi_device::punchmania_inputs_callback)
ksys573_state *state = machine().driver_data<ksys573_state>();
double *pad_position = state->m_pad_position;
int pads = state->m_pads->read();
for( int i = 0; i < 6; i++ )
if( ( pads & ( 1 << i ) ) != 0 )
pad_position[ i ] = 5;
switch( input )
case ADC083X_CH0:
return pad_position[ 0 ]; /* Left Top */
case ADC083X_CH1:
return pad_position[ 1 ]; /* Left Middle */
case ADC083X_CH2:
return pad_position[ 2 ]; /* Left Bottom */
case ADC083X_CH3:
return pad_position[ 3 ]; /* Right Top */
case ADC083X_CH4:
return pad_position[ 4 ]; /* Right Middle */
case ADC083X_CH5:
return pad_position[ 5 ]; /* Right Bottom */
case ADC083X_COM:
return 0;
case ADC083X_VREF:
return 5;
return 5;
static MACHINE_CONFIG_FRAGMENT( punchmania_cassette_install )
MCFG_DEVICE_MODIFY( "adc0838" )
MCFG_ADC083X_INPUT_CB( konami573_cassette_xi_device, punchmania_inputs_callback )
MACHINE_CONFIG_END
int pad_light[ 6 ];
WRITE8_MEMBER( ksys573_state::punchmania_output_callback )
double *pad_position = m_pad_position;
char pad[ 7 ];
switch( offset )
case 8:
output_set_value( "select left right", !data );
break;
case 9:
pad_light[ 2 ] = !data;
output_set_value( "left bottom lamp", !data );
break;
case 10:
pad_light[ 1 ] = !data;
output_set_value( "left middle lamp", !data );
break;
case 11:
output_set_value( "start lamp", !data );
break;
case 12:
pad_light[ 0 ] = !data;
output_set_value( "left top lamp", !data );
break;
case 13:
pad_light[ 4 ] = !data;
output_set_value( "right middle lamp", !data );
break;
case 14:
pad_light[ 3 ] = !data;
output_set_value( "right top lamp", !data );
break;
case 15:
pad_light[ 5 ] = !data;
output_set_value( "right bottom lamp", !data );
break;
case 16:
if( data )
pad_position[ 0 ] = 0; // left top motor +
break;
case 17:
if( data )
pad_position[ 1 ] = 0; // left middle motor +
break;
case 18:
if( data )
pad_position[ 1 ] = 5; // left middle motor -
break;
case 19:
if( data )
pad_position[ 0 ] = 5; // left top motor -
break;
case 20:
if( data )
pad_position[ 2 ] = 0; // left bottom motor +
break;
case 21:
if( data )
pad_position[ 3 ] = 5; // right top motor -
break;
case 22:
if( data )
pad_position[ 3 ] = 0; // right top motor +
break;
case 23:
if( data )
pad_position[ 2 ] = 5; // left bottom motor -
break;
case 26:
if( data )
pad_position[ 5 ] = 0; // right bottom motor +
break;
case 27:
if( data )
pad_position[ 4 ] = 0; // right middle motor +
break;
case 30:
if( data )
pad_position[ 4 ] = 5; // right middle motor -
break;
case 31:
if( data )
pad_position[ 5 ] = 5; // right bottom motor -
break;
sprintf( pad, "%d%d%d%d%d%d",
( int )pad_position[ 0 ], ( int )pad_position[ 1 ], ( int )pad_position[ 2 ],
( int )pad_position[ 3 ], ( int )pad_position[ 4 ], ( int )pad_position[ 5 ] );
if( pad_light[ 0 ] ) pad[ 0 ] = '*';
if( pad_light[ 1 ] ) pad[ 1 ] = '*';
if( pad_light[ 2 ] ) pad[ 2 ] = '*';
if( pad_light[ 3 ] ) pad[ 3 ] = '*';
if( pad_light[ 4 ] ) pad[ 4 ] = '*';
if( pad_light[ 5 ] ) pad[ 5 ] = '*';
popmessage( "%s", pad );
DRIVER_INIT_MEMBER( ksys573_state,pnchmn )
gx700pwfbf_init( &ksys573_state::punchmania_output_callback );
I will tinker around and try to get those motor I/Os to work and aply some hooks to them.... also need to recompile mame now xD.
Is it the right file where i can mess with the motors? First i want to simulate their behaiviour and then make I/Os to put real motors instead.
If someone has this cabinet could you plz contact me. I need some verification on how the cabinet "should" work.
