Author Topic: Adding specific resolution to Arcade_OSD  (Read 2424 times)
xga
  • Last login:August 01, 2026, 11:01:59 am
« on: December 13, 2015, 09:07:37 am »
Hi Guys,
I have an auto tri-sync monitor (Nanao MS-2931) and I'm wanting to add a particular medium resolution and refresh rate (specifcally 496x384 @ 57.5Hz) to the selections list in Arcade_OSD.  Is this relatively straight forward to do?  Does anyone have any pointers on how to do this?
Thanks in advance
haynor666
  • Last login:September 14, 2026, 03:38:01 pm
  • retro maniac
Re: Adding specific resolution to Arcade_OSD
« Reply #1 on: December 13, 2015, 11:32:41 am »
The fastests way will be add it to ResList.txt file  "496 x 384 @ 57.500000" and re-run VMaker with changes in ini - ListFromXML = 0; GeneratreXML = 0
Of course that way You need also add other resolution that You need for Your monitor because VMMaker runned this way will overwrite everything created previously.
« Last Edit: December 13, 2015, 11:36:55 am by haynor666 »
