Author Topic: Need for speed underground pc won't let me choose graphics options  (Read 12362 times)
xenphor
  • Last login:January 13, 2016, 05:18:20 pm
I'm trying to play nfs underground on the pc but everything defaults to low graphics settings and I can't change anything. The 3dsetup dialog menu only has options to change resolution and triple buffering. It doesn't even let me change the resolution either. Does anybody know how to fix this? I'm on windows 7 64bit with a 750ti.
So it's stuck at 640x480 and looks like this:
« Last Edit: December 11, 2015, 03:28:42 am by xenphor »
  • Moderator
Re: Need for speed underground pc won't let me choose graphics options
« Reply #1 on: December 11, 2015, 09:17:43 am »
Just a shot in the dark, but try installing the directX9 runtimes linked to in the Model 2 setup guide sticky.
http://forum.arcadecontrols.com/index.php/topic,131527.0.html
New versions don't contain the older runtimes which older games and emulators need.
You probably would have run into issues with emulators before now if you didn't have them, but it's worth a try.
xenphor
« Reply #2 on: December 11, 2015, 11:23:34 am »
This is not through emulation. It's the pc version.
  • Moderator
« Reply #3 on: December 11, 2015, 11:30:59 am »
...and it's an old game that probably used Directx9
VirtuaIceMan
  • Last login:September 09, 2025, 07:52:27 am
« Reply #4 on: December 14, 2015, 08:17:26 am »
I think you set the resolution inside the in-game options. The menu is usually at 640x480 if I recall correctly...
Check out my racing game videos, including every PC F1 and Rally game ever, over here: https://www.youtube.com/user/VirtuaIceMan/
xenphor
« Reply #5 on: December 30, 2015, 04:45:30 am »
Ya I finally found the options in the display menu.
