Author Topic: Cruisin Exotica pots questions  (Read 2172 times)
Dutsk
  • Last login:January 10, 2026, 12:36:11 pm
« on: December 08, 2015, 08:54:44 pm »
Hi all
Been looking at converting my Cruisin Exotica to a console cabinet as I bought it w/o the arcade pcb in it. I was wondering a few things about the game. Already looked through the manual.
Is it single or dual axis?
What size are the pots? EDIT:::::: I've found out they are 5k ohm
What is a good easy console wheel to hack that could be compatible with existing arcade parts?
Please help Before I break out the multimeter and poke around where I am uncertain.
Below is all I get from manual
« Last Edit: December 08, 2015, 09:45:13 pm by Dutsk »
  • Last login:Today at 05:30:55 am
Re: Cruisin Exotica pots questions
« Reply #1 on: December 08, 2015, 09:52:09 pm »
Page 86 of the manual here, right side, 2/3rds of the way down you can see the foot pedals part of the schematic.
The two pots are wired in parallel -- both have 5v to tab 1 (or 3?) and both have ground to tab 3. (or 1?)
Both pots have an output on tab 2 -- brake on ORG VIO wire, gas on ORG GRY.
This is a standard "dual axis" configuration.
Steering pot P/N 5014-12909-00 is a 5k.  Twisted Quarter has them here.
Pedal pots P/N 50-8026-00 (or 96-4916-00?) are also 5k.
