Author Topic: I can't get my Mala frontend to boot directly on startup using Win7.  (Read 5935 times)
ozzman_8
  • Last login:December 22, 2021, 02:46:13 pm
I can't get my frontend to start directly when I turn on the computer. I don't really care about eliminating the windows icons, I just want the frontend to start without having to select the folder, and run the program.
What I did was I ran the mala, right clicked, selected options/configuration, selected GUI, selected Mala start, then checked start with windows. After I selected ok I get a message saying "Windows did not allow Mala to change registry for Mala start with windows. Try Changing Windows user security settings and/or Antivirus settings."
I've tried changing all the windows security settings and Antivirus settings and nothing. What other steps do I need to do or what am I doing wrong? Any help would be appreciated. I am not new to arcades but I am new to Mame. Thanks
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
Re: I can't get my Mala frontend to boot directly on startup using Win7.
« Reply #1 on: December 05, 2015, 07:59:16 am »
You could try running Mala as admin (right click on the mala.exe and select 'run as adminstrator'). Otherwise, just put a shortcut to mala in your Windows startup folder.
ozzman_8
« Reply #2 on: December 05, 2015, 08:12:37 pm »
Ok, I'll try both of those and see how it goes. I will let you know. Thanks
ozzman_8
« Reply #3 on: December 05, 2015, 08:31:34 pm »
Run as administrator worked... Thanks
