Author Topic: iso than initrd extract usr cant find local ?  (Read 3511 times)
gmtransman2
  • Last login:August 27, 2022, 10:10:37 pm
« on: December 01, 2015, 09:19:57 pm »
need help if you can. i have disk one, than open isolinux, initrd, extract. than i find usr but no local. after that im lost.
mahkeymike
  • Last login:November 21, 2025, 04:40:35 pm
Re: iso than initrd extract usr cant find local ?
« Reply #1 on: December 02, 2015, 08:53:37 am »
Why are you trying to extract initrd, and for what version?
Also, why are you looking for the /usr/local directory?
If you really want to extract initrd use 7-zip and extract initrd twice. Once initrd~ and then again initrd~~, select yes to all on confirm replace box.
gmtransman2
« Reply #2 on: December 02, 2015, 09:42:24 pm »
what im trying to do is follow your instructions that you posted back in jan 20 2014 under megatouch announces closure  , page two. im new to  this and just want to learn. i don't know how else to ask the question i want to ask but i think you know what im wanting to do. i just need pointed in the right direction.thanks
mahkeymike
« Reply #3 on: December 02, 2015, 10:14:43 pm »
Well, im not a mind reader. If you want to patch initrd to install on non official hardware then you need to patch the correct installer for the version you want to install. I am going to assume its 2014 you want to install. The file you are looking for is libinstaller.so in /usr/local/lib
the function that contains the checks is installer::setup
Im not going to sugar coat it for you, and most definitely not publicly. I gave you a good starting point, enjoy.
