Author Topic: Problems with vertical layout and 32" 1366x768 display  (Read 3076 times)
ivwshane
    • My first mame cab! (WIP)
« on: November 26, 2015, 08:41:52 am »
I'm at a loss. I created a vertical layout on my computer and when I tested it on the same computer it worked. However when I tested it on the computer I was using 720p resolution and the TV I'll actually be using is not a true 720p TV.
I transferred the layout folder to the new computer and changed all the paths to the new computer. I loaded mala and specified all the correct paths and wish I launch mala the only thing I see from the layout is the text in the correct color. I thought it might be issues with the background so I redid it to match the TV's resolution, I updated the layout and saved it.
What am I missing?
ivwshane
Re: Problems with vertical layout and 32" 1366x768 display
« Reply #1 on: November 26, 2015, 07:59:28 pm »
I finally got it working.
Somehow I saved the background in 24 bit color and mala wasn't having it.
I also had to do the layout using free aspect ratio and setting the aspect ratio to free.
Now the only problem I have is that my custom gif animation doesn't show up and by bit showing up I mean it doesn't even show up in the layout editor despite having it checked.
Is there a way to delete the video2 if you can't see the box to change its properties?
