Author Topic: Ligh gun on Mame (Pi)  (Read 7119 times)
a7mag3ddon
  • Last login:December 14, 2021, 02:38:54 pm
« on: November 22, 2015, 01:29:20 pm »
Hi all,
not sure if this is quite the right forum but hope it is. I recently got an Aimtrak Light Gun and think it should work as it emulates a USB Mouse?
Has anyone got a gun working on it yet? Can anyone point me to what file i need to edit to enable it?
I read somewhere about creating a mame.ini and setting lightgun to 1 but i cant find where i read it.
Any help greatly appreciated.
Many thanks.
ark_ader
  • I glow in the dark.
Re: Ligh gun on Mame (Pi)
« Reply #1 on: December 28, 2015, 10:50:14 pm »
I think drivers would be an issue, but I do have a topgun and a spare pi to test.......
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
« Reply #2 on: February 01, 2016, 03:23:57 pm »
The aimtrak automatically installs as a usb mouse/hid in windows, no outside driver needed (and seemingly, no real os requirement? I'd have to imagine it could work on a mac.)
Ideally, you could plug it in over usb and it should show up as a generic usb mouse. The only thing you'd potentially lose out on for the pi is the aimtrak utility for adjusting things such as button assignments, ir gain, and recoil, but I think those settings get saved to the gun's memory internally. You could change them to your liking on your computer and then hook it up to the pi.
Granted I have not tried this but that's my thinking. If generic mouse drivers are robust for the pi it might be worth a shot! The topgun however does require a specialty device driver so slim to no chance of that working out.
Jesperpark
  • Last login:March 16, 2021, 12:24:05 pm
« Reply #3 on: February 22, 2016, 03:24:05 pm »
Just a bump on this, also to see if there is anyone who has tried this?  I don't have the Aimtrak but I am looking for a project to use a Pi with.  Thinking like a Pi, 2 Aimtraks in a pelican case, a protable shooting game setup
Thoughts??
Cheers,
burn_654
« Reply #4 on: February 25, 2016, 10:48:04 am »
If you already have a pi, maybe a valuable test to do would be plugging two usb mice into it and seeing if they can pick up as separate player 1 and player 2 crosshairs in mame for pi. If that works then your chances of aimtraks working out should be good. Aimtraks basically show up as 2 rawinput mice so the determining factor for me would be checking if pi mame can do multiple mice well.
mike5im5
  • Last login:December 23, 2021, 03:22:21 pm
« Reply #5 on: April 07, 2016, 09:50:46 am »
Yes the Aimtrak will be detected as a mouse on raspbian. So it's down to what ever software you're using to emulate to support the mouse input. I've got many light gun games working (operation wolf/thunderbolt, terminator 2, zero point etc) running under advance mame that comes with the latest retropie dist.
ark_ader
« Reply #6 on: April 27, 2016, 03:49:21 pm »
Top Guns did not work on the Pi. (Thank God) The whole idea of powering it would eventually cause a fire.
It worked great on CoinOPS though!!!   >:D
