Author Topic: Rowe Ami r-93 not playing vinyl  (Read 2045 times)
debferal
  • Last login:November 23, 2015, 03:39:32 pm
  • jukebox addict !
« on: November 22, 2015, 06:47:33 am »
HI Im hopeing someone might be able to help me I have a record /cd rowe it has been working fine then today it selects the record trys to play but the needle just sits on the edge  if you manually place it on it slides back to the edge. the cds are still working ....if I hold the arm slightly up and go over the record it clicks at the end and selects next record ....not sure at were to look for problem?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe Ami r-93 not playing vinyl
« Reply #1 on: November 23, 2015, 11:18:59 am »
Hi,
You need to check out your tone arm cam adjustments and inspect the tone arm cam for any damage on it.
I would also check that the sylus is not damaged ant that the tone arm wires are not catching on anything.
Regards
Alan
Alan Hood
ami-man
UK
