Author Topic: Rowe amplifier options  (Read 5145 times)
irishflynn
  • Last login:December 16, 2015, 05:18:56 pm
« on: November 20, 2015, 11:47:08 am »
Hello- I recently purchased 2 Rowe Jukeboxes - an R-88 and R-91.
Neither of them have an amplifier, and the R-91 is missing the control board, while the R-88 is missing the tone arm.
I am wondering if the control boards are interchangeable, are the tone arms interchangeable?
- What amps are needed or would work for each of these?
Any thoughts or suggestions?
Ken Layton
  • Guru
  • Technician
irishflynn
Re: Rowe amplifier options
« Reply #2 on: November 23, 2015, 09:36:02 am »
Thanks- do you have any idea where/ if there is a round to square connector adapter for those amps? I have found a few amps with round connectors, but both of mine have the square?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #3 on: November 23, 2015, 11:31:29 am »
Hello irishflynn,
Welcome to the forum.
The technology changed from the R-88 to R-89 9the R-91 is two models up from the R-89)
The Mechanism Controls are slightly different (they have trimmers for adjusting the home & index electronically)and the R-89 onwards used a different opto switch and the CCC changed to the smaller type.
Yes you can swap over the tone arms.
Regards
Alan
Alan Hood
ami-man
UK
irishflynn
« Reply #4 on: November 24, 2015, 11:05:13 am »
Thanks Ken and Alan-
I looked at the links sent- however, since I don't have any amps, I'm not certain I can purchase one as that site looks to be an exchange only. Would the CD100 type amps be an option? I realize they are 250 watts- up from the 130 watt that I think was used with these machines, but it appears that they may work - plug wise?
Thanks very much for your help and assistance- it is very much appreciated.
Tim
ami-man
« Reply #5 on: November 25, 2015, 05:46:52 am »
Hi Tim,
Yes you can use the 250 watt CD amplifiers, but make sure that the phono shorting plug is present (the three pin molex plug) this is a good indication that the Pre-Amplifier board has components fitted to support use on a vinyl jukebox, some of the pre amps did not support use on vinyl so be careful.
If you use a 250 watt amplifier use the lower E tapping numbers on the output package I would use E3 or E4 on left and right rather than the maximum E6 tappings.
Regards
Alan
Alan Hood
ami-man
UK
irishflynn
« Reply #6 on: December 02, 2015, 02:27:48 pm »
Thanks Alan-
Would a r94 computer my compatible with my r91 Jukebox?
ami-man
« Reply #7 on: December 03, 2015, 11:34:31 am »
Hi Tim,
I sent you a PM.
Yes they should be ok.
Regards
Alan
Alan Hood
ami-man
UK
