Author Topic: Control Panel, your opinion  (Read 1566 times)
fablog
  • Last login:May 20, 2026, 11:26:49 pm
« on: November 09, 2015, 09:48:29 pm »
Hi guys,
What do you think about this control panel. I used the sega player 1 and player 2 layouts.
Thanks for any advice  :D
« Last Edit: November 09, 2015, 09:51:42 pm by fablog »
severdhed
  • RIP Dinosaur Hippo
Re: Control Panel, your opinion
« Reply #1 on: November 09, 2015, 10:36:40 pm »
looks pretty good to me.  the only thing i'd be concerned about is the player 1 button 6 looks pretty close to the trackball. If i did the conversions properly, it looks like there may only be a few mm between the trackball housing and the button nut.  I'd just double check to make sure there is enough clearance there.
  • Last login:Today at 04:28:37 am
« Reply #2 on: November 09, 2015, 10:41:44 pm »
What are your plans for admin buttons?
I assume since there are only two shown that they are P1 + P2 Start, with the rest (Coin 1, Coin 2, Exit, Pause, etc.) handled with shifted functions and/or a coin door.
fablog
« Reply #3 on: November 10, 2015, 07:00:08 am »
Severdhed: My friend Paulo made me  this plan in 3D, including the U-trak, to check the clearance with the pushbutton and it's OK. But I didn't think to check the clearance with the button nut. Should be OK but better to be sure, I'll let you know. Thanks.
PL1: you assumed correctly :) I don't want too many buttons in the CP.
« Last Edit: November 10, 2015, 07:04:14 am by fablog »
« Reply #4 on: November 10, 2015, 07:01:46 am »
I built several control panel tops to test.
I found the player 2 layout to be more comfortable for both players.
fablog
« Reply #5 on: November 10, 2015, 07:06:25 am »
Badmouth: Thanks for the advice. I will give it a try. It could be better for the aesthetic too.
