Author Topic: Changing tube to vertical orientation and wacky di  (Read 3203 times)
TDD
« on: July 08, 2002, 02:40:17 am »
I have a tube that works fine horizontally, but, as expected, the colors distort when I make it vertical (as it is for a cocktail cabinet).  I have read the following fixes:
1)  Do nothing and let it adjust itself via built in degaussing on the tube
2)  Perform a manual degauss with the appropriate tool to correct the issue
3)  Have the tube's yoke, etc., readjusted for vertical orientation.
Tell me - which is true?  It's a WG U3100, btw.
TDD
Carsten Carlos
  • Last login:June 28, 2014, 05:06:25 am
  • Projects: Centipede extended, Asteroids
    • Carlos' Centipede-extended
Re: Changing tube to vertical orientation and wack
« Reply #1 on: July 08, 2002, 03:10:02 am »
Try 1) -if it doesn't help (the degaussion-coil on the U3100 is called to be weak), go to step 2 which should always work unless your house is surround from strange magnetics!
3) Nope.
