Author Topic: Ultrastick 360 Problems - Any advice?  (Read 2184 times)
jwwaldre
« on: November 08, 2015, 08:16:33 pm »
First, yes I've sent an email to Andy.  ;)
In case he can't figure out the issue, I wanted to see if any of you have had experience with this.  I'm all out of ideas here.   :banghead:  :dunno
Problem: ULTRAMAP will only recognize one Ultrastick 360 joystick at one time (despite both having different ID#).  Windows detects the joysticks fine as Ultrastick #1 and #2... all buttons work and joysticks work.  Oddly enough, I can move the crosshair in the little preview window in ULTRAMAP by moving the joystick, even though ULTRAMAP says it's "not detected."
Other Details:
1) Windows 7
2) I've tried restarting, unplugging all USB cables, reinstalling ULTRAMAP.  None of those work.
3) If only one joystick is plugged in, ULTRAMAP detects it fine as #1 or #2.  The instant you plug in #1... #2 goes grey and is "undetected."
Other Other Details:  Everything was working fine with both controllers until I let one of the USB cables get too taut.  It ruined the PCB board for joystick #1, so I had to replace it.  The new PCB board could not be detected, so I reinstalled ULTRAMAP... now it detects #1 fine... but it won't detect both joysticks at the same time.
Please help!  My head is about to explode!  :timebomb:
Ginsu Victim
  • Comanche, OK -- USA
Re: Ultrastick 360 Problems - Any advice?
« Reply #1 on: November 08, 2015, 08:53:36 pm »
Where are you plugging in the USB? There's a chance they might not be getting enough power with both plugged in. Try a powered USB hub or USB ports that are hardwired to the motherboard.
jwwaldre
« Reply #2 on: November 08, 2015, 10:13:41 pm »
Thanks for the advice.
Unfortunately, both joysticks are plugged directly in to the motherboard, so there's not much I can do to improve the situation.
1) Based on your recommendation, I tried switching around the USB cables to see if a different port would help.  No luck so far.
2) I have a powered USB hub somewhere.  I'll dig it out and see if it will help.  Knowing my luck, it will probably break something else.  :badmood:
jwwaldre
« Reply #3 on: November 08, 2015, 10:40:51 pm »
Update: Okay, tried the powered usb hub.  No change in behavior.  Second joystick is still "undetected" but can still move the crosshair in the preview window.  Weird.  :'(
lamprey
« Reply #4 on: November 09, 2015, 12:16:46 pm »
I can't help you with your issue, but I recall reading that some people had to re-flash their sticks. You should contact Andy at Ultimarc and work with him to resolve your issue(s).
jwwaldre
« Reply #5 on: November 09, 2015, 08:49:17 pm »
For anyone following along - Andy responded today.
My joystick PCBs are apparently different versions (purchased about one year apart), which he thinks may be causing the issue.  Ordering a replacement board today to see if that will fix the issue.
It's going to be a looooong ten day wait.  Keeping my fingers crossed.
