Author Topic: Crt emu driver and hd 2600  (Read 1872 times)
Joselv81
  • Last login:November 10, 2015, 10:20:02 pm
« on: November 06, 2015, 06:50:51 pm »
Hello I have posted before needing help with another problem so I decided to get another pc and try again. I have a intel core 2 quad with what I believe is a hd 2600 running windows 7 64 bit fresh install. I can change it to 32 bit if need be. But here is the problem I  uninstall the windows driver run the setup with admin rights installs driver then i don't restart yet i check the soccer then it says its a 2600 xt so what is going on here?  Thanks in advance
Calamity
  • Moderator
  • Last login:Yesterday at 01:14:24 pm
  • Quote me with care
Re: Crt emu driver and hd 2600
« Reply #1 on: November 10, 2015, 03:47:20 am »
So the driver works? Just a naming issue?
(if you want to know your card model for sure, check its hardware pci identifier inside the device manager)
Steps to create a log:
Joselv81
« Reply #2 on: November 10, 2015, 11:31:15 am »
Well it installs but my arcade monitor does not sync up correctly still I am thinking I have the wrong card after all. But I will check later on today in device manager
