Author Topic: Jpac standoffs  (Read 2087 times)
keilmillerjr
  • Web Developer.
Jpac standoffs
« on: November 03, 2015, 08:57:46 am »
Can anyone help me find a size or source for pcb standoffs for my jpac? I can't find my caliper right now, so I'm not sure of the pcb hole size. Mounting surface is 3/16 inch. Standoff can me hard mounted or adhesive backed. I ordered some adhesive ones and they were too large.
Re: Jpac standoffs
« Reply #1 on: November 03, 2015, 11:41:37 am »
Do you need something like this?   My thought is that you could use PC screws to fasten the plastic parts to the metal bracket using standoffs.
http://www.ebay.com/itm/Arcade-Game-Board-Legs-25-PCB-Mounting-Feet-Jamma-Multicade-Pinball-etc-/252150368615?hash=item3ab5554967
If so, I have many left and you are welcome to have what you need for your project...  (I'll even send metal motherboard standoffs and screws just in case.  I have tons.)
PM me your mailing address.
DeLuSioNaL29
« Last Edit: November 03, 2015, 11:45:32 am by DeLuSioNal29 »
Re: Jpac standoffs
« Reply #2 on: November 03, 2015, 11:50:37 am »
Forgot to note:  I also have a bulk pack of these.  As a backup solution, you can zip tie the PCB to these standoffs, and then stick them to the Metal.
DeLuSioNaL29
  • Last login:March 31, 2026, 11:05:22 pm
Re: Jpac standoffs
« Reply #3 on: November 03, 2015, 11:50:54 am »
Steal a few of these from work and cut to size.
Re: Jpac standoffs
« Reply #4 on: November 03, 2015, 11:57:23 am »
+1.  Bic pens have saved me in a pinch and they work well.   :applaud:
D
keilmillerjr
  • Web Developer.
Re: Jpac standoffs
« Reply #5 on: November 03, 2015, 09:50:25 pm »
Spent time looking for a solution, yet the solution was right in front of me. Took a small round file and widened the hole slightly to fit my 0.119" to 0.125" self adhesive pcb stand offs. Problem solved. :)
Excuse my mess on the table.
Re: Jpac standoffs
« Reply #6 on: November 05, 2015, 11:30:51 am »
Oh OK, so you widened the holes on the PCB itself.    :applaud:
Glad you found a solution!
D
Slippyblade
Re: Jpac standoffs
« Reply #7 on: November 05, 2015, 02:38:04 pm »
I just with the adhesive stand-offs weren't so expensive.  :(
keilmillerjr
  • Web Developer.
Re: Jpac standoffs
« Reply #8 on: November 05, 2015, 04:14:56 pm »
They are expensive, relative to other items. However, for a total of $4 I now have an easy solution that is nice and neat. This mame setup is going in my neo geo mvs. I want everything easily removable to preserve it. BTW- This mame setup will only run neo geo games. :)
PCB Standoffs - Nylon Locking - Self Adhesive - 0.119" to 0.125" Hole - 8pack
