Author Topic: K7000 hula repair or wiggling screen  (Read 1338 times)
menace
« on: October 28, 2015, 01:23:55 pm »
I wanted to document this here for anyone with the same issue and for my future self (hey dude, you look awesome  ;))
Anyways, this came to me as a previously capped K7000 19".  There was also a new flyback installed.  The screen would do a slow motion hula but was otherwise bright and clear.
I pulled the str3123 (which is electrically the same as a str30123 with pins 1 and 3 reversed) and checked it against a known good one (virtually the same values as posted for the str30130 located in the FAQ here on this board).  Anyways, it came up as different so I swapped in the good one...no change.
There was already a new filter cap installed and the voltages came up ok so I pulled the C36 safety cap and replaced it with another one.
That did it--rock solid picture after that.
Hope that helps someone...
baritonomarchetto
  • Last login:January 02, 2026, 04:27:00 am
Re: K7000 hula repair or wiggling screen
« Reply #1 on: October 28, 2015, 02:40:44 pm »
Thanks for sharing!
