Author Topic: need help wiring switch  (Read 2046 times)
General_Faliure
  • Last login:April 28, 2026, 01:58:35 am
    • My Arcade Cab
« on: October 26, 2015, 02:57:49 am »
Hello.
I bought this switch as part of an arcade parts kit at Aliexpress.
I wonder if someone could tell me exactly how to wire this;
« Last Edit: October 26, 2015, 02:59:24 am by General_Faliure »
My Arcade cab: https://goo.gl/photos/yE1KACHryQjCaaCj7
Core2 duo8400 @3.6 Ghz, 4Gb of mem, Geforce 9500.
Linux Mint 17.3 XFCE, Mame, Mess, Daphne FS-Uae, Mednafen and some more.
Mah!cade
  • Last login:Yesterday at 10:31:33 pm
General_Faliure
    • My Arcade Cab
Re: need help wiring switch
« Reply #2 on: October 27, 2015, 03:10:44 am »
Thanks, i'll give it a go.
Mah!cade
General_Faliure
    • My Arcade Cab
« Reply #3 on: October 29, 2015, 12:13:26 pm »
It works.
Tried it with a light bulb first, when that worked o.k. i connected my cab to it.
Mah!cade
deezdrama
  • Last login:January 25, 2024, 09:45:32 pm
    • forum.arcadecontrols.com/index.php/topic,146268.0.html
« Reply #4 on: October 29, 2015, 07:17:27 pm »
I just ordered one of these for my cab too , plus some 10a 5x20mm fuses (hope the amperage /size is right?)
Do you know what size disconnect I need for it? I have .187 and .250 on hand and a couple bigger ones in garage so hope one of the sizes is right.
Anyway.... I got my smart surge strip and a 12ft 18awg pc power cord......
This is my first cab and not super savy on electrical diagrams.
So I cut off the plug of my smart strip and wire the......
White to B , then a white jumper from A to 1
Then black to D, and black jumper from C to 4
Then ground to 2
Right  :dunno
« Reply #5 on: October 29, 2015, 08:01:50 pm »
The amperage should be fine.
Can't confirm the needed physical size without looking at the sale listing.   :dunno
0.250" should be the right size.
Then ground to 2
You got it.
P.S. You can link to wiki/forum images instead of attaching them.
- Right-click on desired image -- "Copy image location".
- Move the blinking cursor to the location in the post where you want to insert the image.
- Click on to insert the IMG tags
- Paste (Ctrl-V)
deezdrama
« Reply #6 on: October 29, 2015, 08:07:58 pm »
Then ground to 2
You got it.
- Paste (Ctrl-V)
Heres the ebay link
http://pages.ebay.com/link/?nav=item.view&id=251989423296&alt=web
Doesnt mention fuse size that I could see
« Last Edit: October 29, 2015, 08:10:00 pm by deezdrama »
deezdrama
« Reply #7 on: October 30, 2015, 06:15:32 am »
I found this switch outlet on amazon and several reviews say that the switch got hot and melted and could cause a fire  :o
Looks to be the same exact ones me and the OP got.
I wonder if they wired them wrong or if these are just dangerous?
They solved the issue by just wiring the outlet and bypassing the switch/fuse. You would still have protection from the surge strip right?
Any thoughts on this?
« Reply #8 on: October 31, 2015, 09:05:44 am »
Added power wiring inspection procedures to the wiki entry.
http://newwiki.arcadecontrols.com/index.php?title=Wiring#Inspecting_Power_Wiring
General_Faliure
    • My Arcade Cab
« Reply #9 on: October 31, 2015, 11:37:49 am »
My switch is slightly different then yours, it came with the fuse installed, 5 Amps / 250 Volts, if i read it right. (i am from the Netherlands)
Mine has only three connectors at the bottom.
I got it right using the wiki.
Try it with a light bulb first to be sure.
Mah!cade
