Author Topic: crt_emudriver and Retroarch  (Read 3302 times)
R-Typer
  • Last login:September 09, 2024, 12:50:41 pm
  • C64 Rulez!!!!
« on: October 24, 2015, 10:32:56 am »
How to setup Retroarch to work with 240p resolutions? When I select to run a Genesis rom, screen flickers and instead of 320x240 it goes to 720x576i. The Display Driver set by default is GL. If I select D3D or SL2 then Retroarch crashes. I tried SNES and NES cores and they fail to choose lowres progressive resolutions as well.
Does anyone have experience with Retroarch and crt_emudriver? I can't find any help on Retroarch forums regarding this.
Thanks for any help in advance!!!
« Last Edit: October 24, 2015, 11:00:43 am by R-Typer »
cyb
  • Last login:December 19, 2025, 04:07:20 pm
Re: crt_emudriver and Retroarch
« Reply #1 on: October 24, 2015, 08:57:39 pm »
Retroarch is a pain in the ass to set up, but works pretty well once you get it going. You will need to add a few things in the config file.  By default, retroarch uses whatever your desktop resolution is, so you need to put this in the config file:
Code: [Select]
video_windowed_fullscreen = "false"
Also add the resolution you want. In your case it would be this:
Code: [Select]
video_fullscreen_x = "320"
video_fullscreen_y = "240"
I would recommend making a config file for each system.
rtyp3r
  • Last login:March 22, 2025, 02:41:44 pm
« Reply #2 on: October 25, 2015, 07:59:19 am »
Thank you so much!!!
cyb
« Reply #3 on: October 25, 2015, 04:31:22 pm »
No problem.  :) I've spent several hours configuring retroarch. I'm considering making a guide on using it with 15khz monitors. A lot of it was just trial and error.
u-man
  • Last login:May 20, 2024, 03:53:16 pm
« Reply #4 on: October 25, 2015, 09:11:32 pm »
in depth config-file-tutorial: https://gist.github.com/Monroe88/dbd3e01252afa5c50690
just exchange with your intended resolution ;)
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
cyb
« Reply #5 on: October 25, 2015, 09:20:49 pm »
That is great! bookmarking.
