Author Topic: Newbie question about coin switch wiring  (Read 1832 times)
nickfredmick
  • Last login:August 11, 2018, 09:05:19 am
« on: October 14, 2015, 01:28:08 pm »
Hi,
Apologies in advance if the answer to this question is already on the forum, I do try a bit of research before posting a question, but last time I posted and 20 seconds later my question was answered so its tempting to go this route.
I am wiring up my coin door lamps and switches on my Xybots machine.  The existing wires seem to be 24 AWG according to my gauge, the tabs on the coin switch terminals are 6.3mm (.25"), but I cant find female connectors in both these sizes anywhere.
Does anyone know where I can get connectors in this size?
Will I be ok just going with a 6.3mm for 22-18 AWG?
Thanks for any replies, cheers.
Slippyblade
Re: Newbie question about coin switch wiring
« Reply #1 on: October 14, 2015, 01:33:43 pm »
You can use .250" connectors, but you'll need to strip extra wire and double it over so you shove a double thickness into the crimp.
Personally, I solder my connections.
nickfredmick
« Reply #2 on: October 14, 2015, 01:40:47 pm »
A guy on youtube said that doubling over the wire could cause a short circuit, is this not anything to worry about in this instance?
I can see that learning to solder is inevitable at some point, but im starting with crimping and building up.
Thanks for replying.
Slippyblade
« Reply #3 on: October 14, 2015, 01:51:18 pm »
I fail to see how stripping a little extra on the end and folding it over would cause a short...
Here's a good convo about doing this exact thing.
http://www.vansairforce.com/community/archive/index.php?t-47538.html
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #4 on: October 14, 2015, 02:04:25 pm »
i just solder directly to the button terminals. One less point of failure. Also faster and cheaper.
nickfredmick
« Reply #5 on: October 14, 2015, 02:39:29 pm »
quote: If it makes you feel better the Boeing Standard Wiring Practices Manual includes that very procedure for small gauge wires
This is reassuring, I will go down this route with the larger connectors.
But in future soldering is the way to go, then I don't have to shell out on connectors at all, seems obvious now.
Thanks for your helpful replies.
