Author Topic: Rowe Ami R-91 free play  (Read 4671 times)
Coach6745
  • Last login:December 10, 2015, 09:51:15 pm
« on: October 12, 2015, 10:01:28 pm »
I just purchased a 1987 Rowe Ami R-91 jukebox
I would like to set it too free play, but the previous owner could not remember how to do it.
Can anyone tell me how to it to free play
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe Ami R-91 free play
« Reply #1 on: October 13, 2015, 08:24:41 am »
Hello & welcome to the forum.
You need to get into programming, at location 27 type in 255 and press the popular button curser through all the other location and then switch of the service switch, turn it back on there should be 255 now in the display which means the jukebox is on free play.
Regards
Alan
Alan Hood
ami-man
UK
Coach6745
« Reply #2 on: October 17, 2015, 12:23:59 pm »
Alan,
Don't have clue what your talking about. Can you please detail the answer more.
Were is location 27 ?
Coach6745
« Reply #3 on: October 17, 2015, 12:31:54 pm »
One more problem.
it will pick record on and place on turn table, but when it tries to pick it up its falls out of the gripper arm. Is there a adjustment on the gripper arm?
ami-man
« Reply #4 on: October 20, 2015, 07:02:51 am »
Location 27 is in the CCC programming, this is accessable via the service switch in the service position.
Please see your jukebox manual it will show you how to do this.
With regards to your gripper bow, I suggest that you remove it and fully strip it down and clean all the parts in warm soapy water, inspect all the parts for any wear and replace if necessary.
Regards
Alan
Alan Hood
ami-man
UK
Coach6745
« Reply #5 on: October 20, 2015, 11:01:40 pm »
Where can I get a service manual?
ami-man
« Reply #6 on: October 21, 2015, 05:31:50 am »
Hello Coach6745,
What country do you live in?
If you are in the USA then go onto www.victoryglass.com, in Europe look at www.jukebox-world.de or look on Ebay.
Regards
Alan
acevedor2
  • Last login:May 25, 2024, 08:21:24 pm
« Reply #7 on: November 08, 2015, 07:40:55 am »
Coach where are you located. I have the exact same model and just did this on mine about two weeks ago. I would be happy to walk you through it and I could even copy the sections of the manual for you. Just let me know.
Dedicated - Working:
Asteroids Deluxe
Firefox
Galaxian
Pacman
Viruta Fighter 2
Zombie Raid
Pool Sharks - Pinball
Projects:
Pole Position
Pole Position 2
Coach6745
« Reply #8 on: November 08, 2015, 12:28:38 pm »
Thanks for all your help, I purchased a service manual, we are now on free play, and everything is working perfectly!
