Author Topic: Best Setting for Pal TV  (Read 1715 times)
Giddygoon
  • Last login:March 22, 2022, 04:13:04 am
« on: October 09, 2015, 04:06:28 am »
Hi Calamity,
I have bought two 14" CRT TVs which are plugged via Scart into the Ultimate Scart Adapter then goes to an Arcade Vga card putting out CGA 15khz
The picture is great on both but I'm using an INI file from another arcade cab with the generic_31 setting
Should I change this too Pal TV?
Or something else for best fit?
Thanks again for any help
Paradroid
  • Last login:July 12, 2025, 08:11:33 pm
    • SCART Hunter
Re: Best Setting for Pal TV
« Reply #1 on: October 09, 2015, 04:30:23 am »
Personally, I would try the generic_15 preset and, if that works fine, try your luck with arcade_15. Most SCART TVs with be fine with this.
Out of the 50 to 100 SCART TVs I've tested, only one was stricly PAL only. Really, most SCART TVs can sync to anything in the PAL to NTSC range so it's better to use one of the presets mentioned.
Out of interest, what brands are your two TVs?
My MAME/SCART/CRT blog: SCART Hunter
Giddygoon
« Reply #2 on: October 09, 2015, 09:47:07 am »
The brand of TV's is a Bush 1485 14" I use these for cocktails tables as they have memory from power on.... So it's jumps straight to last channel selected which in my case is AV 1
Great picture too
Thanks for info
