Author Topic: odd Kortek symptom  (Read 1350 times)
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
odd Kortek symptom
« on: October 05, 2015, 07:27:39 pm »
referencing an OLD post here:
http://forum.arcadecontrols.com/index.php/topic,77766.msg811797.html#msg811797
had one today doing the relay click  as descibed.   found 14v source low - around 8v.
caps checked ok .
switched to resistance checks - vert out ok
did find a 24 ohm load off the output of  IC106 (5v line)
chased it to the neck board and then to B+ on IC801  WT6802
certainly didn't expect this . will have to order the chip as non stk item..........
MonMotha
Re: odd Kortek symptom
« Reply #1 on: October 07, 2015, 01:02:52 am »
You've got to be kidding me.  What the hell would make that part fail?  It's about as low power and isolated from anything major as you can get.
When ordering replacements, you might want to watch out as it's available in 4 different packages with various features exposed.  Looks like the 2914 uses the smallest, 16-pin package.  The stupid datasheet doesn't even give an ordering info section to construct the full part number for a given package.  You might just have to call the supplier up to confirm what they have.
qrz
« Reply #2 on: October 24, 2015, 03:04:15 pm »
a gassy CRT.
customer brought in that tube with another "working" chassis that died upon pwr up
once had that chassis going, had a nice purple glow on the gun assy' .
seems killed it fast enough to not undo the repair . ok on another tube.
at least it wasn't a full blown 2nd anode short.
that kind of fireworks tends to get one's attention rather quickly.
'splains alot don't it ?
MonMotha
« Reply #3 on: October 24, 2015, 09:10:11 pm »
I'm still a little surprised it took out something as straightforward and isolated as the OSD generator and nothing else.  I would have certainly expected the video pre-amp to be more exposed.  Was the cause simply a power/voltage excursion, and that chip happens to be the weakest and hence first thing to go?  If it fails shorted and shuts down the power supply, that would make sense.
