Author Topic: [Solved]Switchres not working with Rocketlauncher  (Read 4630 times)
CitrikElektrik
  • Last login:January 18, 2019, 05:13:53 am
« on: October 04, 2015, 06:46:06 am »
Hi everyone,
I hope to find a solution here.
I am using groovymame 0.165 and everything works perfectly when I launch it for the command line.
This is the output when I launch Super Side Kick 2 :
Code: [Select]
SwitchRes: [ssideki2] (1) horizontal (320x224@59.19)->(320x224@59.19)
Average speed: 99.97% (8 seconds)
When Groovymame is launched from HyperSpin 1.4 and Rocket launcher, I get the following :
Code: [Select]
SwitchRes: could not find a video mode that meets your specs
SwitchRes: v0.015i, Monitor: generic_15, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Monitor range 15625.00-15750.00,49.50-65.00,2.000,4.700,8.000,0.064,0.192,1.024,0,0,192,288,448,576
SwitchRes: \\.\DISPLAY1: ATI Radeon HD 4300/4500 Series
SwitchRes: DeviceKey: System\CurrentControlSet\Control\Video\{A1F8F821-6E7F-48A3-8827-9111A0F60D7C}\0000
Switchres: Searching for custom video modes...
Switchres: [  1]  240x 160 @ 60 : DALDTMCRTBCD240x160x0x60 - Modeline "240x160_60 15.66KHz 59.98Hz" 5.01 240 256 280 320 160 202 205 261   -hsync -vsync
Switchres: [  2]  240x 200 @ 60 : DALDTMCRTBCD240x200x0x60 - Modeline "240x200_60 15.66KHz 59.98Hz" 5.01 240 256 280 320 200 222 225 261   -hsync -vsync
Switchres: [  3]  248x 192 @ 60 : DALDTMCRTBCD248x192x0x60 - Modeline "248x192_60 15.65KHz 59.98Hz" 5.26 248 264 288 336 192 218 221 261   -hsync -vsync
Switchres: [  4]  256x 192 @ 60 : DALDTMCRTBCD256x192x0x60 - Modeline "256x192_60 15.65KHz 59.97Hz" 5.51 256 272 304 352 192 218 221 261   -hsync -vsync
Switchres: [  5]  256x 224 @ 60 : DALDTMCRTBCD256x224x0x60 - Modeline "256x224_60 15.65KHz 59.97Hz" 5.51 256 272 304 352 224 234 237 261   -hsync -vsync
Switchres: [  6]  256x 239 @ 60 : DALDTMCRTBCD256x239x0x60 - Modeline "256x239_60 15.65KHz 59.97Hz" 5.51 256 272 304 352 239 241 244 261   -hsync -vsync
Switchres: [  7]  256x 240 @ 60 : DALDTMCRTBCD256x240x0x60 - Modeline "256x240_60 15.65KHz 59.97Hz" 5.51 256 272 304 352 240 242 245 261   -hsync -vsync
Switchres: [  8]  256x 244 @ 60 : DALDTMCRTBCD256x244x0x60 - Modeline "256x244_60 15.82KHz 59.94Hz" 5.57 256 272 304 352 244 245 248 264   -hsync -vsync
Switchres: [  9]  256x 256 @ 59 : DALDTMCRTBCD256x256x0x59 - Modeline "256x256_59 16.19KHz 58.46Hz" 5.70 256 272 304 352 256 258 261 277   -hsync -vsync
Switchres: [ 10]  320x 224 @ 60 : DALDTMCRTBCD320x224x0x60 - Modeline "320x224_60 15.64KHz 59.91Hz" 6.63 320 336 368 424 224 234 237 261   -hsync -vsync
Switchres: [ 11]  320x 240 @ 60 : DALDTMCRTBCD320x240x0x60 - Modeline "320x240_60 15.64KHz 59.91Hz" 6.63 320 336 368 424 240 242 245 261   -hsync -vsync
Switchres: [ 12]  320x 244 @ 60 : DALDTMCRTBCD320x244x0x60 - Modeline "320x244_60 15.85KHz 60.03Hz" 6.72 320 336 368 424 244 245 248 264   -hsync -vsync
Switchres: [ 13]  320x 256 @ 58 : DALDTMCRTBCD320x256x0x58 - Modeline "320x256_58 16.18KHz 58.41Hz" 6.86 320 336 368 424 256 258 261 277   -hsync -vsync
Switchres: [ 14]  336x 224 @ 60 : DALDTMCRTBCD336x224x0x60 - Modeline "336x224_60 15.66KHz 60.00Hz" 6.89 336 352 384 440 224 234 237 261   -hsync -vsync
Switchres: [ 15]  384x 240 @ 60 : DALDTMCRTBCD384x240x0x60 - Modeline "384x240_60 15.63KHz 59.90Hz" 7.88 384 400 440 504 240 242 245 261   -hsync -vsync
Switchres: [ 16]  512x 448 @ 60 : DALDTMCRTBCD512x448x0x60 - Modeline "512x448_60 15.64KHz 60.03Hz" 10.51 512 536 584 672 448 466 471 521 interlace  -hsync -vsync
Switchres: [ 17]  512x 478 @ 60 : DALDTMCRTBCD512x478x0x60 - Modeline "512x478_60 15.64KHz 60.03Hz" 10.51 512 536 584 672 478 481 486 521 interlace  -hsync -vsync
Switchres: [ 18]  512x 480 @ 60 : DALDTMCRTBCD512x480x0x60 - Modeline "512x480_60 15.64KHz 60.03Hz" 10.51 512 536 584 672 480 482 487 521 interlace  -hsync -vsync
Switchres: [ 19]  512x 512 @ 58 : DALDTMCRTBCD512x512x0x58 - Modeline "512x512_58 16.18KHz 58.29Hz" 11.00 512 536 592 680 512 515 520 555 interlace  -hsync -vsync
Switchres: [ 20]  544x 242 @ 60 : DALDTMCRTBCD544x242x0x60 - Modeline "544x242_60 15.72KHz 59.98Hz" 11.19 544 568 624 712 242 243 246 262   -hsync -vsync
Switchres: [ 21]  640x 200 @ 60 : DALDTMCRTBCD640x200x0x60 - Modeline "640x200_60 15.67KHz 60.05Hz" 13.04 640 664 728 832 200 222 225 261   -hsync -vsync
Switchres: [ 22]  640x 400 @ 60 : DALDTMCRTBCD640x400x0x60 - Modeline "640x400_60 15.60KHz 59.88Hz" 12.98 640 664 728 832 400 442 447 521 interlace  -hsync -vsync
Switchres: [ 23]  640x 480 @ 60* : DALDTMCRTBCD640x480x0x60 - Modeline "640x480_60 15.60KHz 59.88Hz" 12.98 640 664 728 832 480 482 487 521 interlace  -hsync -vsync
Switchres: [ 24]  768x 512 @ 58 : DALDTMCRTBCD768x512x0x58 - Modeline "768x512_58 16.21KHz 58.41Hz" 16.34 768 800 880 1008 512 515 520 555 interlace  -hsync -vsync
SwitchRes: Found 24 custom of 24 active video modes
SwitchRes: -resolution was forced as 2560x0
SwitchRes: -resolution value not available: 2560x0
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.015i:[ssideki2] Calculating best video mode for 320x224@59.185608 orientation: normal
SwitchRes: [ 240]x[ 160]_(60=59.9847Hz) - locked
SwitchRes: [ 240]x[ 200]_(60=59.9847Hz) - locked
SwitchRes: [ 248]x[ 192]_(60=59.9770Hz) - locked
SwitchRes: [ 256]x[ 192]_(60=59.9732Hz) - locked
SwitchRes: [ 256]x[ 224]_(60=59.9732Hz) - locked
SwitchRes: [ 256]x[ 239]_(60=59.9732Hz) - locked
SwitchRes: [ 256]x[ 240]_(60=59.9732Hz) - locked
SwitchRes: [ 256]x[ 244]_(60=59.9356Hz) - locked
SwitchRes: [ 256]x[ 256]_(59=58.4585Hz) - locked
SwitchRes: [ 320]x[ 224]_(60=59.9080Hz) - locked
SwitchRes: [ 320]x[ 240]_(60=59.9080Hz) - locked
SwitchRes: [ 320]x[ 244]_(60=60.0341Hz) - locked
SwitchRes: [ 320]x[ 256]_(58=58.4079Hz) - locked
SwitchRes: [ 336]x[ 224]_(60=59.9962Hz) - locked
SwitchRes: [ 384]x[ 240]_(60=59.9004Hz) - locked
SwitchRes: [ 512]x[ 448]_(60=60.0345Hz) - locked
SwitchRes: [ 512]x[ 478]_(60=60.0345Hz) - locked
SwitchRes: [ 512]x[ 480]_(60=60.0345Hz) - locked
SwitchRes: [ 512]x[ 512]_(58=58.2919Hz) - locked
SwitchRes: [ 544]x[ 242]_(60=59.9847Hz) - locked
SwitchRes: [ 640]x[ 200]_(60=60.0498Hz) - locked
SwitchRes: [ 640]x[ 400]_(60=59.8848Hz) - locked
SwitchRes: [ 640]x[ 480]_[60=59.8848Hz] - locked
SwitchRes: [ 768]x[ 512]_(58=58.4144Hz) - locked
SwitchRes: Setting option -noswitchres
Video: Monitor 00000000003D7938 = "\\.\DISPLAY1" (primary)
Direct3D: Warning - Unable find any D3D9 DLLs; disabling post-effect rendering
Direct3D: Using Direct3D 9
window_proc: WM_NCACTIVATE
blit_lock = TRUE
Direct3D: Configuring adapter #0 = ATI Radeon HD 4300/4500 Series
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 8192x8192
Direct3D: Device created at 640x480
blit_unlock = TRUE
RawInput: APIs detected
Input: Adding Kbd #0: Périphérique clavier PIH
Input: Adding Mouse #0: Souris HID
Input: Adding Gun #0: Souris HID
Input: Adding Kbd #1: Périphérique clavier PIH
Input: Adding Kbd #2: Périphérique clavier PIH
Input: Adding Kbd #3: Périphérique clavier PIH
DirectInput: Using DirectInput 8
window_proc: WM_PAINT
blit_lock = FALSE
window_proc: WM_PAINT:END
stream_buffer_size = 37888
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Region ':maincpu' created
Region ':fixed' created
Region ':fixedbios' created
Region ':zoomy' created
Region ':mainbios' created
Region ':audiobios' created
Region ':audiocpu' created
Region ':ymsnd' created
Region ':sprites' created
Starting Super Sidekicks 2 - The World Championship / Tokuten Ou 2 - real fight football (NGM-061)(NGH-061) ':'
Optional device 'cartslot6' not found
Optional device 'cartslot5' not found
Optional device 'cartslot4' not found
Optional device 'cartslot3' not found
Optional device 'cartslot2' not found
Optional device 'cartslot1' not found
  (missing dependencies; rescheduling)
Starting M68000 ':maincpu'
Starting Z80 ':audiocpu'
Starting Video Screen ':screen'
Optional device 'finder_dummy_tag' not found
Starting palette ':palette'
Starting Neogeo Sprites ':spritegen'
Starting Speaker ':lspeaker'
Starting Speaker ':rspeaker'
Starting YM2610 ':ymsnd'
Starting NeoGeo Banked Cartridge ':banked_cart'
Starting uPD4990A RTC ':upd4990a'
Starting NVRAM ':saveram'
Starting NeoGeo Memory Card ':memcard'
Starting NeoGeo Protection (Metal Slug X) ':mslugx_prot'
Starting NeoGeo SMA Cartridge ':sma_prot'
Starting NeoGeo Protection (CMC) ':cmc_prot'
Starting NeoGeo Protection (NEOPCM2) ':pcm2_prot'
Starting NeoGeo Protection (PVC) ':pvc_prot'
Starting NeoGeo Protection (Bootleg) ':bootleg_prot'
Starting NeoGeo Protection (KOF2002) ':kof2002_prot'
Starting NeoGeo Protection (Fatal Fury 2) ':fatfury2_prot'
Starting NeoGeo Protection (KOF98) ':kof98_prot'
Starting NeoGeo Protection (Super Bubble Pop) ':sbp_prot'
Average speed: 100.02% (5 seconds)
Sound: buffer overflows=1 underflows=0
blit_lock = TRUE
window_proc: WM_DESTROY
blit_lock = TRUE
The Rocketlauncher log is the following :
Code: [Select]
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - LegacyMode: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - LegacyMode: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - LegacyMode: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - MAME_BIOS_Path: F:\Hyperspin\Emulators\Mame0.165\roms
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - Videomode: ini
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - PauseMethod: 1
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - BilinearFilter: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - BilinearFilter: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - HLSL: ini
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - HLSL: ini
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - HLSL: ini
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - GLSL: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - GLSL: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - GLSL: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - BezelMode: layout
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - BezelMode: layout
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - BezelMode: layout
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - VerticalRotationMode: none
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - VerticalRotationMode: none
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - VerticalRotationMode: none
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - CheatMode: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - CheatModeKey:
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - UseSoftwareList: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - StaticParameters:
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - Parameters:
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - Parameters:
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - MameRomName:
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - Autosave: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - Autosave: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [Settings] - Volume:
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - Volume:
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - Volume:
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - Artwork_Crop: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - Artwork_Crop: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Bezels: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - Use_Bezels: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Overlays: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - Use_Overlays: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Backdrops: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - Use_Backdrops: true
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Cpanels: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - Use_Cpanels: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Marquees: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [ssideki2] - Use_Marquees: false
11:45:22:720 | MD |     INFO  | +0     | Module Setting - [MAME] - IniPath:
11:45:22:720 | MD |     INFO  | +0     | Module - Detected MAME Product Version from 'F:\Hyperspin\Emulators\Mame0.165\mame64.exe' is 165
11:45:22:720 | MD |     INFO  | +0     | Module - Running MAME in legacy Mode
11:45:22:720 | MD |     INFO  | +0     | Run - Running: F:\Hyperspin\Emulators\Mame0.165\"mame64.exe" ssideki2 -nowindow -rompath "F:\Hyperspin\Roms\MAME;F:\Hyperspin\Emulators\Mame0.165\roms"
11:45:22:751 | MD |     INFO  | +32    | Run - Showing Command Window to troubleshoot launching. ProcessID: 2772
11:45:23:126 | MD |   DEBUG1  | +374   | Run - ""mame64.exe" ssideki2 -nowindow -rompath "F:\Hyperspin\Roms\MAME;F:\Hyperspin\Emulators\Mame0.165\roms"" Process ID: 2772
11:45:23:126 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: Administrateur : C:\Windows\system32\cmd.exe - "mame64.exe"  ssideki2 -nowindow -rompath "F:\Hyperspin\Roms\MAME;F:\Hyperspin\Emulators\Mame0.165\roms"  | Class: ConsoleWindowClass | State: 0 | X: -2 | Y: 75 | Width: 669 | Height: 342 | Window HWND: 0x6043a | Process ID: 2772 | Process Path: C:\Windows\SysWOW64\cmd.exe
11:45:23:126 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class MAME"
11:45:23:391 | MD |   DEBUG1  | +265   | GetActiveWindowStatus - Title: MAME: Super Sidekicks 2 - The World Championship / Tokuten Ou 2 - real fight football (NGM-061)(NGH-061) [ssideki2] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0x2a02c0 | Process ID: 800 | Process Path: F:\Hyperspin\Emulators\Mame0.165\mame64.exe
11:45:23:391 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: MAME: Super Sidekicks 2 - The World Championship / Tokuten Ou 2 - real fight football (NGM-061)(NGH-061) [ssideki2] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0x2a02c0 | Process ID: 800 | Process Path: F:\Hyperspin\Emulators\Mame0.165\mame64.exe
11:45:23:391 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class MAME"
11:45:23:496 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: MAME: Super Sidekicks 2 - The World Championship / Tokuten Ou 2 - real fight football (NGM-061)(NGH-061) [ssideki2] | Class: MAME | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0x2a02c0 | Process ID: 800 | Process Path: F:\Hyperspin\Emulators\Mame0.165\mame64.exe
11:45:23:505 | MD |     INFO  | +0     | Process - WaitClose mame64.exe
11:45:32:974 | MD |   DEBUG1  | +9470  | CloseProcess - Started, user requested to end launched application
11:45:32:974 | MD |     INFO  | +0     | WinClose - Closing: ahk_class MAME
11:45:33:201 | MD |   DEBUG1  | +234   | CloseProcess - Ended
11:45:33:201 | MD |     INFO  | +0     | ExitModule - Started
11:45:33:201 | MD |     INFO  | +0     | Starting Updating Statistics:
11:45:33:201 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
11:45:33:201 | MD |   DEBUG2  | +0     | gameSectionStartTime:3971223
11:45:33:201 | MD |   DEBUG2  | +0     | ElapsedTime:10
11:45:33:201 | MD |   DEBUG2  | +0     | Statistics cleared game name: ssideki2
11:45:33:234 | MD |   DEBUG2  | +31    | Loaded game statistics from ini files:
Number_of_Times_Played: 19
Last_Time_Played: dimanche octobre 4, 2015 11:43:08
Average_Time_Played: 46
Total_Time_Played: 868
System_Total_Played_Time: 3755
Total_Global_Played_Time: 6201
11:45:33:234 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 20
Last_Time_Played: dimanche octobre 4, 2015 11:45:22
Average_Time_Played: 44
Total_Time_Played: 878
System_Total_Played_Time: 3765
Total_Global_Played_Time: 6211
11:45:33:265 | MD |     INFO  | +31    | Game section statistics updated.
11:45:33:265 | MD |   DEBUG1  | +0     | ExitModule - Closing command window: cmd.exe PID: 2772
11:45:33:265 | MD |     INFO  | +0     | Process - Close cmd.exe
11:45:33:265 | MD |     INFO  | +0     | ExitModule - Ended
11:45:33:265 | MD |     INFO  | +0     | End of Module Logs
11:45:33:374 | RL |     INFO  | +10779 | Main - Module ended, exiting RocketLauncher normally
11:45:33:374 | RL |     INFO  | +0     | ExitScript - Started
11:45:33:374 | RL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
11:45:33:374 | RL |     INFO  | +0     | ExitScript - Ended
Do you know what I missed ?
Thanks for your support.
« Last Edit: October 04, 2015, 11:32:36 am by CitrikElektrik »
Calamity
  • Moderator
  • Last login:Today at 04:14:45 am
  • Quote me with care
Re: Switchres not working with Rocketlauncher
« Reply #1 on: October 04, 2015, 08:38:54 am »
For some reason the configuration that GM is accessing when launched from HS contains the "resolution 2560x0" option, just as if you were intending to use super resolutions, when it's not the case. Switchres can't find any 2560x mode and fails. Just set resolution to auto.
Steps to create a log:
CitrikElektrik
« Reply #2 on: October 04, 2015, 08:54:44 am »
Thanks for your reply Calamity (and for your awesome job by the way !).
In fact I do want to use super resolutions. The mame.ini used by GM should be the same when launched from the command line than from Rocketlauncher. The one on the same directory than the executable file.
I forgot to set resolution 2560x0 some days ago and games like Mortal Kombat were very slow (around 52%).
Calamity
  • Moderator
« Reply #3 on: October 04, 2015, 09:03:34 am »
You haven't created any super resolution through vmmaker, judging by your log.
Actually I don't get the reason why it should be working at all from command line.
« Last Edit: October 04, 2015, 09:07:55 am by Calamity »
CitrikElektrik
« Reply #4 on: October 04, 2015, 11:32:19 am »
This was exactly the problem. I messed up with the reslist.txt and took the wrong one the last time I ran vmmaker.
Thanks for your support !
