Author Topic: Metal control panels - anyway to mount sticks without bolts showing?  (Read 1947 times)
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
I'm guessing the answer is no already, but I thought I'd ask anyways.
Is there anyway to mount controls on a metal control panel without having the bolts showing on the top?  I was thinking you could maybe weld a nut on the botton side, but then the bolt would only be holding on the stick by a couple threads.
Anyone accomplished this?
lance
Setabs
  • Last login:March 07, 2015, 03:03:23 pm
  • 100% MAME compatible.
    • Another Useless Webpage
Re:Metal control panels - anyway to mount sticks without bolts showing?
« Reply #1 on: January 07, 2004, 01:10:04 am »
I would have to say to weld some threaded bolts without the top onto the bottom of the cp.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: January 07, 2004, 01:10:13 am »
by a couple of threads?  get longer bolts.
My ddragon2 cab has welded on threads.
Lance
  • banned
« Reply #3 on: January 07, 2004, 01:20:30 am »
Now if I only knew how to weld! ;)
Any rough idea what a metal shop would charge for something like this?
« Reply #4 on: January 07, 2004, 04:27:34 am »
Depending how thick your panel is, and what bolts you can find you *may* be able to use countersunk bolts...assuming you are covering the panel with artwork of some kind.
Stingray
« Reply #5 on: January 07, 2004, 10:06:16 am »
"Any rough idea what a metal shop would charge for something like this?"
If you go in with your nuts or bolts ready to go and your panel marked up as to where they are to be welded, most guys I know would probably do it for nothing or next to nothing. This is a five minute or less welding job.
-S
Ken Layton
  • Guru
  • Technician
« Reply #6 on: January 07, 2004, 10:32:59 am »
As someone who has built many control panels over the years, I have used 10-24 by 1" long FLATHEAD machine screws. Of course we had it lucky in that Ziegler's Welding was located directly across the street from our shop here in Olympia, Washington! I'd take the panel across the street with the bolts and the position clearly marked and 5 minutes later (and $10 later) have a nice panel with spot welded bolts for the joysticks.
