Author Topic: Help creating INI file.  (Read 1597 times)
langlem
  • Last login:May 27, 2025, 04:58:19 pm
« on: September 23, 2015, 07:54:26 pm »
Hello,
Getting back into MAME and am very rusty.  I am building a cocktail cab and am 95% done.  I have an old Dell Optiplex computer and only loading like 20-40 classic arcade games.  I have nearly completed the control panel with a SH usb trackball.  Computer recognizes it but mame does not.  So I go to tne MAME32 folder to open ini file and its not there.  I have an old version 32bit .144 nonag and hi score which works fine on a different computer.
I can open the command line and everything but when I get to the -cc or create config step I get a message on the next line that reads ""desktop\mame32-createconfig is not recognized as an internal or external command, operable program or batch file.
Can someone remind me or help me out here.  I am sure it is beyond simple...i just can't figure it out.
Matt
  • Last login:Today at 04:47:14 am
Re: Help creating INI file.
« Reply #1 on: September 23, 2015, 08:16:07 pm »
1. You need to be in the same folder as the executable when you enter the command.
2. There should be a space between the MAME executable filename (mame32.exe, right?) and "-cc".
Typing "mame32 -cc" into the command line while in the same folder as the executable should do the trick.   ;D
langlem
« Reply #2 on: September 23, 2015, 08:54:33 pm »
Thanks for the reply!  I am missing something simple here... And am stunned tnat I have been screwing with this for THREE hours now.  Should take 2 minutes.
Can you help me step by step... And its ok to talk to me like a 2nd grader because thats about how smart I feel.  I mean I have gotnmy Hyperspin working perfect...computer decased and mounted...cab put together and I can not get the damned trackball working.  Its Budweiser time!
Im not sure by what you mean... In the exe folder.  How do i get there from the black command prompt box??
Sorry...its been years since I played around with this...very much appreciated!
« Reply #3 on: September 23, 2015, 09:25:49 pm »
Here's the easiest way AFAIK:
1. Using Windows Explorer, navigate to your MAME folder and find the "mame.exe" or "mame32.exe" file so you know what filename to use in step 4.
2. Shift + right-click on a blank part in the right-half Windows Explorer window -- not on a file or folder.
3. Select "Open command window here".
4. Type "mame -cc" or "mame32 -cc". (executable filename without the .exe plus the -cc)
langlem
« Reply #4 on: September 23, 2015, 10:48:06 pm »
Got it!  Thanks for the help!
As I said....pretty rusty on all of this!!
Have a good one!
Matt
« Reply #5 on: September 27, 2015, 08:22:02 pm »
Another quick way to do it is to create a shortcut of the MAME executable on your desktop by right clicking it.
Then right click on the shortcut, select properties and add -cc to the command line at the end. Click OK. Double-click the shortcut. Boom!
Then feel free to kill the shortcut.
